computer to non computer???
Old Aug 8, 2006 | 05:51 PM
fg_stadium's Avatar
I have a 91 z28 with a 305 tpi and I'm switching to a carbbed 350,if I bypass the computer will all my gauges and everything else work?and will I have to change the distributer too?
Old Aug 8, 2006 | 06:11 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Gauges will work. You will need a new distributor. And if it's an automatic you'll need a computer simulator that plugs into the tranny.
Old Aug 8, 2006 | 06:15 PM
fg_stadium's Avatar
it has the 700r4 and I was told that i can unplug the electrical connectors on the tranny and it will work fine, just wont have the lock up feature,is this true?
Old Aug 8, 2006 | 06:40 PM
j dezzy's Avatar
Car: 87 TA
as far as my 84 TA goes that's all true. you'll just need a vaccum advance distributor. the computer was just completely cut out of my car. everything works fine. I have a T-5 tranny though so I'm not sure about the lock up features.
Old Aug 8, 2006 | 06:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's also true that your transmission won't live as long without the lock up feature.
Old Aug 8, 2006 | 06:59 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
depends on the trans i didnt have the lockup hooked up on mine and it works fine and that was 2 years ago that it was built ther is a way to hook a toggle switch to it too theres a faq on here somewhere
Old Aug 8, 2006 | 07:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes it "works fine", you're just shortening the life of it, especially if you do a lot of cruising at highway speeds. An external cooler helps, but best is to keep the lockup function working somehow.
Old Aug 9, 2006 | 06:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you're fond of cruise control, check the following:
https://www.thirdgen.org/forums/engi...-function.html
JamesC
Old Aug 10, 2006 | 09:47 PM
camaroboricua's Avatar
Car: 1990 Camaro RS
Engine: 355 c.u.
Mines a t-5 so I wouldnt know about the tranny stuff. But as far as the rest of the stuff what i did is, i checked the factory harness for big power wires, i think i ended up finding 3 10 ga. red wires that made all my accessories work through the original fuse panel. I found themat the battery connector. after that i just eliminated all the extra tbi stuff, check out my page and see how it looks now... hope this helps
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
