How many wires to the starter motor?
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have about 4 smaller wires plus a big heavy wire going to my starter. When I look at the schematic in the Haynes manual I can only account for 2 of these smaller wires. How many should there be? 3 of the 4 look to have fuseable links on them.
I just put a starter on my car and there was 2 extra wires with fusible links on them running to the starter.I have no idea what the extra wires are,are they fusible links?
Matbe someone has added something to the car,as you say they look like fusible links.Sorry,I read the post but did not pick up on the "they are fusible link portion".
Maybe someone has added something to the car,as you say they look like fusible links.Sorry,I read the post but did not pick up on the "they are fusible link portion".
Car: 87 TA
could possibly be for an option of sorts...maybe something dumb like a "rust illiminator". I've seen those on a few cars. maybe push button start? just a few option to throw out there.
Car: 87 IROC
Engine: modded LB9
I am going to disconnect 2 of them and leave the one for the starter and the one that comes from the alternator to try and eliminate the purpose of the other 2. Are there any potential hazards with doing this?
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Did you find out anything? Did all 4 go to the same big post, or did 2 of them go to 2 smaller posts? A "manual" ignition with a resistor can have a 3'rd post on the starter giving 12V straight to the coil to boost spark when cranking.
Car: 87 IROC
Engine: modded LB9
I wont be able to look at it until Thursday as I have been very busy. From what I can remember when fitting the starter all 4 of these wires went to the one post.
mhatfield 14
Oct 24, 2015 07:48 AM
db057
Aug 11, 2015 10:11 PM
