TURN SIGNAL CAM, HOW TO GET TO IT
Old Sep 9, 2006 | 01:33 PM
1989GUNMETALTA's Avatar
i have a problem with my turn signal cam, i can fix that part, the hard part is gettin to it. i took off the steering wheel and the dash out and i dont see how i can get behind the black plastic cover over the column. do i need a special tool, or what? can someone please help me.... thank you
Old Sep 9, 2006 | 02:09 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
that black plastic piece covers the steering wheel lock plate.
you can pry the plastic piece off of the lock plate & then you need a lock plate depressor.
there is some good info here which goes farther than what your doing, but you may want to go ahead & check the screws that cause a loose column as your going to be pretty close anyway.
https://www.thirdgen.org/steeringcolumn
also, if you have VATS on your car & haven't done it yet, you may want to replace the ignition lock cylinder & key at this time too.
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
