Pinouts and connections for 87 tpi
Old Sep 18, 2006 | 08:21 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
I need pinouts and connection colors for the wiring harness on a 87 tpi. I'm changing a car originally equipped with a four barrel to tpi. I'm now in the process of removing all the four barell wiring in order to swap to the tpi harness. I need some info on this. Thanks in advance for all your help.
Old Sep 19, 2006 | 12:15 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
Come on guys. I know someone out there has some info.
Old Sep 22, 2006 | 10:28 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
I'm going to start installing my new harness this weekend. I need some info
Old Sep 23, 2006 | 03:32 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If you were a little more specific in WHAT you need, you might get more help.
I assume you're looking for the c100 and c207 pinouts?
You will get great results if you hit the magical button ...
Lou
Old Sep 25, 2006 | 07:20 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
Well I got the harness installed this weekend. Found everything the old fashion way, trace it back. Only thing is I got a conector with 3 wires on it. two pink/white one brown. I was reading somewhere about these wires and it said it supposed to be a pink for injectors, pink/white for injectors, and brown for fuel pump. Where do these go. There is no connector under my dash for these three wires. Would I be able to just run these three wires to an ignition on hot wire?
Old Sep 25, 2006 | 10:03 AM
BigBadLou's Avatar
Engine: TPI
What year TPI did you swap in?
I'd be very hesitant to connect anything to the pink/white wires because the standar key-on wire color is pink/black. But some older years might differ (that's why I was asking about the year of your TPI setup).
A picture of the connector and its location would definitely help with identification.
Lou
Old Sep 25, 2006 | 10:43 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
It's possible it was pink/black. I can't get a picture of the connector, but it came off a 86 305. the connector is comming out of the computer harness, through the side wall. it's right there with the ecm plugs and the dash harness plugs.
Old Sep 25, 2006 | 11:26 AM
BigBadLou's Avatar
Engine: TPI
What ECM pin does the brown wire go to? If it's let's say A2 on C1, it's for the air select valve. If it comes from A10 on C1, it might be for the vehicle speed sensor buffer.
I wish I could point you to an online schematic but our ATGO (Austin TGO chapter) website is down for host change so the schematics are offline. You can go to the Autozone website for schematics.
Lou
Old Sep 25, 2006 | 12:30 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
Correction.. Sorry. The brown wire is for the cooling fan. I looked on chevy thunder. They say the brown goes to the fuse box to hook with the existing A/C-heater fuse. Got that. The other two are for the injectors. It is pink and black. ChevyThunder says to fuse this to an aftermarket fuse block. So would these two go in with the ignition switch?
Old Sep 25, 2006 | 05:01 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
1986 F-BODY WIRING
Caspar
Jun 19, 2016 11:19 PM
beachrodder
Aug 25, 2015 08:05 AM
mdtoren
Aug 23, 2015 12:52 PM
Sanjay
Aug 12, 2015 03:41 PM
Bull86
Aug 10, 2015 05:43 PM
