changed everything and still nothing
Old Sep 28, 2006 | 06:33 PM
johnblaze322's Avatar
Car: 92 camaro
Engine: V6
ok i changed my alternator belt and new battery but i still get the same result while at and idel such as at a stop light the battery gauge starts to drain but while in park is still good also while driving it shows its charging i am completly lost please help
Old Sep 29, 2006 | 12:27 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Please don't trust your dash volt meter. Take a good DIgital Volt Ohm Meter (DVOM) and check voltage at the battery & at your alternator. If you still have problems after that post back. Put your DVOM across the battery terminals, take a reading-compare it to dash guage, start the car apply the emergency brake & put the trans in gear, take a reading & compare to the dash guage. I bet you will find that the dash gauge is not accurate.
Corky
Old Sep 29, 2006 | 12:51 PM
FGER00's Avatar
Check the wire that comes up from the starter to the alternator, make sure it has not been melted from touching the manifold. That was my problem with the same issue.
Old Sep 30, 2006 | 10:54 AM
Car: 92 camaro
Engine: V6
yeah u were right i dont have a volt meter but parts store does and they said everything was working fine so now whats the next step gettin a new volt meter
Old Oct 1, 2006 | 06:30 PM
Corky's Avatar
Engine: 2.8L
John,
Check car shows, swap meets & ebay for an OEM gauge or go with an aftermarket pillar type gauge set. I usually go aftermarket for volt, temp & oil pressure gauges.
Corky
Old Oct 4, 2006 | 10:15 PM
Car: 92 camaro
Engine: V6
well i think i figured out the prob it wasnt a ground or a faulty gauge it was the my engine idel was too low thats why it wasnt chargin while sitting at a stop light i just changed it and took it for a ride 2nite with the wipers goin head lights on my 2 twelves bumpin and it went down but never past 13 so i think i am ok thanks for your guys help and ill def. update if it starts up again
IROCtometal
Sep 20, 2015 11:08 PM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
