Gauge cluster swap?
Old Dec 15, 2006 | 06:33 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Gauge cluster swap?
Hi all. I was wondering what is involved in swaping an 89 trans am gauge cluster(all gauges), into a 83 firebird(no gauges). The 83 is a 305(lg4). Thank you to all that help.
Old Dec 16, 2006 | 12:06 AM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
i don't think you can, 1. i think they're made different & 2. 83's have mech, speedo's & 89's are electronic,
Old Dec 16, 2006 | 06:07 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Gauge cluster swap
I want to retro fit the newer cluster in my 83. my plan was to run just the wiring from the sensors to the 89 gauges. Get my idea? Is there a mech speedo that was in a 83 that went to 110+?
Old Dec 16, 2006 | 08:30 PM
85camarodude's Avatar
dunno bout the other stuff but u can buy a convertor that goes from mech to electronic or vise versa
Old Dec 16, 2006 | 08:41 PM
redlsone's Avatar
I just but a speedo that is mech thats a 140 that I want to sell. I was told it was for 82?-92 so what do I tell people?
Old Dec 16, 2006 | 08:45 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
try to find an 85 gauge panel, 85's have mech, speedos & the later style gauge faces,
mech, to electric swap:
www.hioutput.com/tech/speedo.html
hope this helps..
Old Dec 18, 2006 | 07:21 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Gauge cluster swap
I found out there is an gauge set that came in a 83 w/tach. My question is other than installing the right sending units(sensors), what esle is involved in switching non-gauges to gauges w/tach?
Old Dec 18, 2006 | 09:55 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
The warning light clusters used a different dash harness than the gauge clusters for the early thirdgen Firebirds. You will need to find a harness from an 83' V8 Firebird that has gauges-(try a bone yard), or re pin your existing IP harness connectors. Also the warning light dash cars used the resistance from the charging light in the dash to switch on the alternator, and start it charging. The gauge cluster cars used a resistance wire running from the ignition switch to turn on the alternator, so all this has to be dealt with too. Lots of people have converted the Camaro from warning lights to gauges as the wiring harness is the same for both, and you only need to swap the sending units for oil pressure, and temp. The Firebird is another story. As far as I know nobody has done a tech write up on switching the Firebird from warning lights to gauges. With no procedures your on your own.
Old Dec 19, 2006 | 08:21 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Gauge cluster swap?
I was planning on removing the; cc-q jet, cc-hei, and installing a one-wire gm alternator. So i just need the dash harness with the gauge cluster?? Maybe i will just install an "autometer dash" I need gauges...if i cant see whats going on with the motor....im not driving it. Also, thanks oldschool for info
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
