No power to starter...
Old Jan 17, 2007 | 02:39 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
OK, the yellow wire from the ignition switch on top of the steering column, across the drivers legs, and down the drivers side kick panel, then under the carpet and would come up as a tan and white wire into the gear selector switch...right?
Whats happening is when we turn to "start", we get power on the yellow wire all the way to where it drops under the carpet...then no power at the tan and white wire on the gear selector switch...so where does it run from where it disappears under the carpet?
We have power to accessories, and the fuel pump is kicking on, even the radio comes on...the brake light on the dash comes on...but when we turn the key to start, we get no attempt to start...
Any ideas?
IF there were a problem with VATS the car WOULD at least try to start, right?
Is there an interlock relay were missing?
Old Jan 17, 2007 | 05:07 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Where is the starter enable relay located?
91 z28
An *EARLY* 91 (manufactured in June of 90)...and would it be located in the same place on a 90? (just in case some of the wiring on this early 91 might be kinda 90ish...already had an issue with the trunk release solenoid where they changed it mid-production)
We have traced power all the way across to the passenger side, to the Pass-Key module (right next to the computer), the purple and white wire (on the PassKey module) has power when we try to start it, but we cant trace where its supposed to go from there (Starter enable relay?).
We suspect the starter enable relay might be bad?
Thanks again!
Old Jan 17, 2007 | 05:33 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Is the 'security' lamp going out when you turn it to the 'run' position ? It should within a second or two.
This might help a little...
Old Jan 18, 2007 | 07:08 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Negative.
The only dash light that comes on (or goes off) is the brake light. Frankly, I dont recall the security light ever coming on. (its been 7 years since this car was running)
We did replace the ignition switch, cause it was frozen solid, I also ordered a 350 chip from TPIChips, and Im positive I had VATS disabled. (will verify)
In that diagram you provided (thank you very much, we have several, but not that one), we have power all the way to circuit 625, thats the black and yellow wire that goes into the PassKey Decoder module.
When you turn the key to start, the test light shows power on circuit 625.
Now we need to trace it from there to where ever it goes?
The starter enable relay?
We tried grounding the blk/yel wire, because it appears that if that wire gets grounded, it would close the starter enable relay, but that didnt help any.
Thank you for your help!
Old Jan 19, 2007 | 08:30 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
No one has a clue?
Old Jan 20, 2007 | 04:59 PM
deadbird's Avatar
Engine: TPI 305/ v6
What you need to do since VATS is disabled in the prom now, is just bypass the relay all together.
On a non-vats vehicle, the yellow wire would run direct to the park/neutral switch. Then, out to a puprple wire which goes to the starter.
In your case, for test, if you jumper from the yellow wire to the dark green wire at the shifter, the car should crank granted it is in park or neutral.
If it doesn't crank then, jumper the yellow to the purple and try. If it does crank then, the P/n switch is bad/broken.
The relay in the VATS circuit is just an interrupt in that circuit.
If the passkey module doesn't see the resistance value from the
key, it will not ground the coil side of the relay to close it. The
relay not closed, it disables the starter.
It's an overly complex on/off switch.
Old Jan 20, 2007 | 06:30 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Thank you muchly!
So does that mean that I can simply unplug the PassKey Module that was mounted up next to the computer?
Old Jan 21, 2007 | 12:09 PM
deadbird's Avatar
Engine: TPI 305/ v6
You should be able to since VATS is disabled in the prom, the input from the passkey is disregarded.
Old Jan 21, 2007 | 02:04 PM
squareone206's Avatar
Does anyone know where I can get a new starter enable relay for a 1989 Iroc? I called shucks and they sayed there is no such part???man they dont know what there doing...........can anyone help me with this thanks
Old Jan 21, 2007 | 09:48 PM
deadbird's Avatar
Engine: TPI 305/ v6
ACDELCO Part # 14093107
Old Jan 21, 2007 | 10:32 PM
Old Jan 27, 2007 | 12:13 AM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
autozone.com for wiring diagrams for your car. Click "vehicle repair guides", then you tell them what car you have, then click "Chassis electrical", then "wiring diagrams".
You'll be able to see everything that could keep your car from starting.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
