gauges are now inaccurate
Old Jan 20, 2007 | 07:44 PM
ishada's Avatar
Car: 91 camaro RS
Engine: Lo3
Axle/Gears: 2.73s I think
I installed new gauges in my 91 rs and now my gauges are inaccyurate I thought I had placed the needles correctly but I guess not. Any way to fix this. If i took it to a dealer to fix how much do you think it would cost?
Old Jan 21, 2007 | 03:01 AM
ishada's Avatar
Car: 91 camaro RS
Engine: Lo3
no one to even tell me I am ****ed? Anyway took her for a cruise battery is all the way right, temp is a little to the left says fully warm at 100* should be closer to 160. RPMs are way off and fuel reads lower but is ok so I fuel up before I have to. I would still like to know my options..thanks ahead of time for help.
Old Jan 21, 2007 | 06:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you installed new gauges, why mess with the needles?
JamesC
Old Jan 21, 2007 | 08:40 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I do not understand why you would touch the needles at all if the gauges were new?
Old Jan 21, 2007 | 09:13 AM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Did you change the face plate?
Old Jan 21, 2007 | 09:30 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Get the car up to operating temp. and take needles off and move them to where you think they should be.
Old Jan 21, 2007 | 09:42 AM
JamesC's Avatar
That could be interesting (and perhaps disastrous).
JamesC
Old Jan 21, 2007 | 10:17 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Not as disastrous as reading 100° low might be.
Old Jan 21, 2007 | 11:30 AM
JamesC's Avatar
I agree, which is why simply guessing doesn't seem to be the best option (though some might say that the OEM gauges are so unreliable that you might as well guess anyway).
JamesC
Old Jan 21, 2007 | 11:48 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
I never said guess, He said, the gauge read 100 when it should be closer to 160. If he knows that for sure then change it, that's all I'm saying. I removed my Voltmeter and my Fuel level gauge needle (another story) but using a power supply and a digital voltmeter replaced them accurately.
I'm not sure how or where to get the temp reading but if his confident he knows the correct temp then go for it.
Old Jan 21, 2007 | 11:55 AM
JamesC's Avatar
As always, each to his own.
JamesC
Old Jan 21, 2007 | 12:01 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Temp is fairly easy. If you have a dual fan setup (tpi), let the engine idle untill the fan kicks on. Pull the temp gauge needle and place @ 220°.
If you have a single fan (tbi, v6), do the same except, when the fan kicks on, it will be 238°.
The fuel and oil gauge read 0-90ohm. Removing the harness plug from the sender and placing an inline 45ohm resistor to ground will make either gauge show half (half tank gas, 30psi oil pressure, if v8).
Old Jan 21, 2007 | 02:12 PM
ishada's Avatar
Car: 91 camaro RS
Engine: Lo3
it was faces sorry for the confusion. Anyway thanx for the help.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
