Taillights all of a sudden gone
Old Jan 25, 2007 | 10:16 PM
Abanda's Avatar
ok so my driver side turn signal went out and so i changed it. i guess the old one was the original or something because it was pretty stuck in there and the glass came off. i had to remove the bottom metla part with a pair of needlenose pliers then all of a sudden the tailights went out!!!. if i step on the brakes they light up but not when i have the headlights turned on like they are supposed to. any ideas???
Old Jan 25, 2007 | 10:27 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
did you disconnect the battery while working on the lights?
Old Jan 25, 2007 | 10:58 PM
Abanda's Avatar
no i had to do it in front of My friends house IN A HURRY and all i had was the pliers
Old Jan 25, 2007 | 11:17 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
was it the front turn signal?
do your panel lights work?
if the answers are yes & no in that order, recheck the bulb & socket for any problems & then check the tail light fuse.
Old Jan 25, 2007 | 11:19 PM
Abanda's Avatar
yeah it was the front turn signal and yes the instrument panel lights work. i was thinking the fuse as well but if i step on the brakes they light up like they are supposed to. only they do not stay on went the headlights are on. i'll check the fuse though just in case.
Old Jan 30, 2007 | 12:33 PM
D3ATH)(TR00P3R's Avatar
Car: 88 Camaro SC
Engine: 305 TBI
Axle/Gears: Posi
Fuseable link?
Old Jan 30, 2007 | 02:14 PM
Abanda's Avatar
done
ok yeah the tails where out becuz the fuse blew. however now the damn blinker light that i was fixing in the fist place is not blinking. the passenger side blinks fine but the driver side stayslit in the rear and dont even turn on in the front. i am going to check the harness fro shorts or something like that.
Old Jan 30, 2007 | 05:18 PM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
Try replacing the bulb again.You can get a bad one easy.
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fronzizzle
Feb 9, 2017 09:31 AM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
pimprs
Sep 10, 2015 03:34 PM
