Instrument panel wiring woes.
Old Feb 2, 2007 | 09:50 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Ok, so the engine swap is complete, and now its just wrapping up the odds and ends...things like....brake lights, the wiring for the gauges, etc...
The first issue is that the tach stays pegged, and when I say pegged, I mean pegged, beyond the range of the gauge itself, pegged against the bottom edge of the dash (or the pin, but I cant see one). It will move BACKWARDS when I start the car though? But wont move at all after starting. (I was able to locate the stuff about the capacitor on the rear of the tach, and printed it all off)
Secondly, none of the idiot lights seem to work...when you first turn the key on, all the lights should light up, and a buzzer or something should sound, yes? Well, none do, except the brake light when you start the car...and no buzzer goes off.
The speedometer doesnt budge at all.
The brake lights dont work.
Headlight switch needs to be replaced. (already bought it)
Etc etc etc...
Anyway, Ive searched and searched and havent been able to find a wiring diagram specifically for the instrument cluster, gauges, idiot lights, etc etc...
If anyone could point me in the right direction, Id be much appreciative...its the only thing keeping the car in the garage now!
PS. All fuses have been replaced to factory specs. But I havent checked to see if any have blown since the car was started the first time.
Old Feb 3, 2007 | 06:08 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Nothin huh?
No one knows where I can find a wiring diagram for the instrument cluster?
Old Feb 3, 2007 | 09:06 PM
WaltB_FB92's Avatar
Car: Pontiac Firebird
Engine: V-8 305
Transmission: Automatic 4-speed
Axle/Gears: non posi
Engine swap
You might look into your ECM and determine if you need a new PROM to match the swapped engine.
Old Feb 3, 2007 | 09:11 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
this is what i have,
Attached Thumbnails Instrument panel wiring woes.-audible-warnings.gif   Instrument panel wiring woes.-cluster-lighting.gif   Instrument panel wiring woes.-coolant-volt.gif
Old Feb 3, 2007 | 09:12 PM
DENN_SHAH's Avatar
and the last of what i have,
to zoom in, open them in windows picture & fax viewer, you may need to save them to your pc first.
Attached Thumbnails Instrument panel wiring woes.-fuel-oil-speed.gif   Instrument panel wiring woes.-high-beam-turn.gif   Instrument panel wiring woes.-tach.gif
Old Feb 3, 2007 | 09:16 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
I did get a new PROM for a 350 (vs 305). I dont know how that would affect the tach, speedo, and idiot lights though?
Thanks DENN_SHAH, i think thats what Im needing
Old Feb 3, 2007 | 09:17 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Help link.
http://www.austinthirdgen.org/module...howpage&pid=22
Old Feb 3, 2007 | 09:33 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Originally Posted by Wadebryant
That was mighty helpful yes!
Complete instrument wiring diagrams, excellent!
Old Feb 3, 2007 | 09:45 PM
Wadebryant's Avatar
BigBabyLou, a member on this board, provided me with help and the info to this link.
Good luck!
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Exxon Limited
Aug 9, 2015 08:13 PM
