need better fuse block diagram
Car: 1992 Camaro RS
Engine: 305 TBI
All,
My car won't start. I can't hear the fuel pump running and the thottlebody is bone dry (TBI). I want to test the fuse, and I know it's a 10A. But, the diagram I have says it's "U" on the diagram. there is no "U" there's several places "U" could be, but I wonder if anyone might have a better diagram before I go out there and start pulling 10A fuses after work.
Thanks.
Thanks.
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
IIRC the fuel pump fuse is located in it's own holder mounted near the battery. There is also a relay mounted on a bracket on the firewall right next to the brake booster.
I love the movie ******....just watched it the other day in fact.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
That's not the fuel pump fuse.it's the ecm fuse.ask me how I know.
Car: 1992 Camaro RS
Engine: 305 TBI
well, I found a better diagram, the fuse in question is a 20A that can/will cut off the ECM, fuel pump relay, and fuel pump/oil pressure sender/switch. I believe the caption on the diagram reads, "we put this in the engine bay because nick doesn't have enough frustration and aggravation already." It kind of makes me feel better that there's still one last fuse to look at, but what are the odds that it is just the fuse?
ok, so the fuse blew. why? boredom?
I guess what I should do is have someone stand there and watch/listen to the injectors to see if they're firing. That'd tell me the ECM is working.
of course, wouldn't it be fantastic if the ECM was toast? I've had my dash out so many times that you'd think I've been paid to do it. They're not cheap either.
I almost want it to be a $35 fuel pump that's only accessible from the top of the tank that's mounted under the car (seriously, access panel, anyone?). my only problem then is 1.) moving the car, 2.) the full-tank of $2.69/gal premium I put in it less than four hours before the thing stopped working, 3.) it's 23F 4.) there's a snowstorm on the way.
****** was hilarious. nothing quite like a bunch of babbling brits. Layer Cake was better for that kind of stuff though.
Car: 1992 Camaro RS
Engine: 305 TBI
my brother's friend tells me that there's an access panel under the carpet behind the rear seat. can anyone confirm that this is on the '92?
nope no panel unless it was done custom.
Car: '89 IROC-Z
No access panel unless the chassis has been hacked on.
The fuse likely blew because the pump is fried, although a short in the wiring is also a distinct possibility.
Fuel pumps have a nasty tendency to die when you fill the car up with gas. It seems that dumping cold fuel on a hot pump just doesn't go over well if the pump is already borderline.
Never seen Layer Cake. I liked "Lock, Stock, and Two Smoking Barrels" though.
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: need better fuse block diagram
my fuse ia a 15amp fuse for the fuel pump and ecm? is that ok? or should i change it to 20amp?
that is how the car came when i bought it from some guy.
just change it back to 20amp? ive been having drivability problems but the fuse looks ok. if it blew i wouldnt be able to drive the car right? what would the lower value do?
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
when the car turns on can u hear the fuel pump?
my gun however d.e 50 where as urs says replica!
Axle/Gears: no idea
fuel pump turns on. but what is the proper value for the fuse? and why do you have to replace it everytime you take it out?
car runs very shitty but it does run. i'm going throguh soooo many issues trying to figure out why certain things are happening.
gta892000
Sep 16, 2015 12:37 AM
