ignition won't turn to acc?
Old Mar 11, 2007 | 12:13 AM
Kandied91z's Avatar
just bought a 91 z28, the when the key is in the car starts fine and turns forward fine but i can't get it to turn backwards to just turn the acc on? do i have to replace the whole section or is there something that possibly sticks? i can live without it unless there is a cheap fix.
Old Mar 11, 2007 | 11:59 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
in my truck that was caused by a bad ignition switch, it was hanging up.
Old Mar 11, 2007 | 12:12 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
My '86 has been like that since I bought it in 98. Unless you listen to the radio for long periods I really don't think you need the ACC. And even when I do listen to the radio I turn it foward one click. If you have a strong battery it really is not a problem. And I know the way you keep your cars battery is the least of your problems. It just was something I decided not to worry about until I have a column or real ignition problem.
Old Mar 19, 2007 | 07:16 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
I'm having the same issue with my 91Z. With the exception of mine feels a little "sticky" going forward as well. Anyone with ideas? Dont really want to spend $60 on an ignition switch.
Old Mar 19, 2007 | 10:27 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
You could try adjusting it. Mike
Old Mar 19, 2007 | 10:53 PM
Toehead's Avatar
That is true, they are on sliders. There is about an 1/8 of an inch of adjustment.
Old Mar 19, 2007 | 11:17 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I've realized that mine does it too. Works fine otherwise, I'm not realy worried about it...
Old Mar 19, 2007 | 11:41 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
I never noticed. I'll have to check that out
Derick15
Sep 17, 2016 05:28 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
ZsTransAm
Aug 11, 2015 07:30 PM
BrianI
Aug 9, 2015 11:52 AM
