oil pressure sending unit wire?
Old Mar 28, 2007 | 12:33 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
hey guys, i swapped out my 305 tpi in my 85 camaro last year and i put in a 383 carbed motor and i dont remember what color the wire is for the oil pressure sending unit. Can anybody help me out? It is a one wire deal isnt it?
Old Mar 28, 2007 | 02:22 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: oil pressure sending unit wire?
Well.... It is a brownish tan wire. To be sure, take it and tap it lightly to ground and watch the pressure gauge. It will move.
Old Mar 28, 2007 | 03:30 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
The only brownish tan wire i can find coming out of my harness from the drivers side is this... but it has a connector and another wire on it.
Old Mar 28, 2007 | 04:02 PM
Toehead's Avatar
That doesnt look like it. On my engine it was in the same bundle as the oil pressure switch.
Old Mar 28, 2007 | 05:25 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
welp we cut the wires we "thought" we didnt need last year so i have no idea where it is. On the main harness coming out of the drivers side there is a white wire that it cut and doesnt go to anything yet. Could this be it? Is this pic there is the white wire with the connector and another connector that i found that could be it too.
Old Mar 28, 2007 | 07:14 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Neither one of those look like the oil press wire. Mine is a single spade type connector with a round rubber grommet as part of the connector.
My 86 and 88 have the same style.
Old Mar 28, 2007 | 10:51 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Hmm.. this is driving my nuts!! For some reason i cannot find the wire to my oil pressure sending unit. I cut the plastic wire loom off all the way down to the firewall/connector on the drivers side harness and there is no tan browish wire except the one on that connector in the first pic ( which i dont know what goes to either). That wire does come out of the drivers side main harness correct?
Old Mar 28, 2007 | 11:59 PM
Toehead's Avatar
Yes, it does come out of the drivers side harness. I'll check again when I get home, and maybe give you more infromation.
Old Mar 29, 2007 | 12:45 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Look at the C100 bulkhead connector and trace the tan wire from pin E5.
Hope this helps.
Lou
Old Mar 29, 2007 | 08:09 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Lou is that the connector at the firewall in the engine bay or up under the dash?
Old Mar 29, 2007 | 11:07 PM
BigBadLou's Avatar
Engine: TPI
Yes, it's the big rectangular connector on the firewall by the brake master cylinder, under the relays.
Lou
Old Apr 3, 2007 | 09:55 PM
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
Just to cap this off, it was the tan wire that went to the connector as shown in the picture above where 1badrocz is holding the green and tan wires. Must've branched after the connector. I knew the sending unit wire came through the connector on the firewall and when no other tan wire could be found, I tested that wire ... and the rest is history.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Irocohio
Aug 12, 2015 08:03 AM
