Dang Horn!
Old Apr 22, 2007 | 10:49 AM
killerklown's Avatar
Car: 1990 Firebird
Engine: 3.1
Dang Horn! **Pix Added**
90 Firebird Horn not working. Used a circuit tester and no power to the horns and no power to the horn buttons. Fuse is good. Buttons on the steering wheel are actually good and contacts are good (airbag style). Looked under the dash, do not see a horn relay like I saw in other photos here (unless its diff on this yr 90).
-Is there a way to test the horns (2 on drivers side near battery) to see if they even blast?
-Can you re-wire it direct w/o all the relay crap?
Any replies would be helpful, NEED a horn here in Los Angeles!
Old Apr 23, 2007 | 08:40 AM
Car: 1990 Firebird
Engine: 3.1
Re: Dang Horn!
Anybody??
Old Apr 23, 2007 | 08:45 AM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: Dang Horn!
There is a horn relay on there. I'm sure of that. It should be right above the Hazard Flasher relay. You know, the 1" aluminum circular relay.
Old Apr 23, 2007 | 08:55 AM
Car: 1990 Firebird
Engine: 3.1
Re: Dang Horn!
Ill take another look. Snap a pic while Im at it.
Old Apr 23, 2007 | 06:00 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
HORNING IN WITH INFO
.................Is there a way to test the horns ......to see if they even blast?..............
You can test the horns by putting voltage to them directly.
Don’t wire them without the relay.
The relay makes sure the horns gets enuff power.
How else are ya gonna blast those slo-pokes
that rubber neck every little fender bender?
Also the relay prevents the horn button from pitting.
( No not a pit-stop I mean corrosion )
Happy Racing !
|__|==(_)==|__|
— If people drove any slower
they’d be going backwards —
Old Apr 23, 2007 | 06:49 PM
Car: 1990 Firebird
Engine: 3.1
Re: Dang Horn!
NINÅ, Since its right next to the battery I would assume you just take 2 wires (pos and a neg) from the battery and touch the connector on the horn to test? (while not letting them touch of course). Got that right?
-I took pics of under my dash, will upload in about an hour. I do not see a "convenience center" under here, just an empty space where its supposed to be (perhaps earlier yrs?) strokermotor91, I think its eluding my eyes.....
1st car Ive ever owned where the horn dont work.
Old Apr 23, 2007 | 08:01 PM
Car: 1990 Firebird
Engine: 3.1
Re: Dang Horn!
Here are pix of under dash. Where abouts is the horn relay??
-btw, anyone know what is that rougue purple wire not connected to anything is?
Old Apr 24, 2007 | 09:36 AM
Car: 1990 Firebird
Engine: 3.1
Re: Dang Horn!
bump...help
Old Apr 24, 2007 | 05:59 PM
Car: 1990 Firebird
Engine: 3.1
Re: Dang Horn!
I need a horn before some putz slams into me!
90 firebird, horn relay is where??? (see pix)
Old Apr 25, 2007 | 02:18 PM
Car: 1990 Firebird
Engine: 3.1
Re: Dang Horn!
Old Apr 25, 2007 | 03:11 PM
j dezzy's Avatar
Car: 87 TA
Re: Dang Horn!
you can test the horn by just hooking it up to the car battery. The horn relay for my 91 bird is under the dash. has your horn worked before?
Old Apr 25, 2007 | 03:21 PM
j dezzy's Avatar
Car: 87 TA
Re: Dang Horn!
Horn relay should be here, along with the a few others
Old Apr 25, 2007 | 03:55 PM
Car: 1990 Firebird
Engine: 3.1
Re: Dang Horn!
Only had the car over a month, horns did not work when I got it.
Old Apr 25, 2007 | 04:02 PM
Car: 1990 Firebird
Engine: 3.1
Re: Dang Horn!
[quote=j dezzy;3317874]Horn relay should be here, along with the a few others
-Ya know, I took off that block box (the buzzer you have circled) and I could see the silver circular hazard relay on top and between the buzzer and that there is an EMPTY space! No doubt that is where my horn relay is supposed to be? Looks like something should plug in there (dk where it disapeared too) Also to the side are 2 20amp fuses that say (hdlps or something like that). Will pick up a new relay tonight at autozone (if they have it in stock) and hope for the best. Cause everything else is hooked up etc....
-And yes, the horns do blast as I tested them to the batt.
Old Apr 25, 2007 | 04:16 PM
j dezzy's Avatar
Car: 87 TA
Re: Dang Horn!
awesome. good luck getting the relay. they should have it in stock. At the zone here they usually have about 8 or so just hanging on a peg hook.
Old Apr 25, 2007 | 08:42 PM
Car: 1990 Firebird
Engine: 3.1
Re: Dang Horn!
It was the horn relay after all! Now it goes BEEP BEEP!!! Here are some pix to help anyone else out w/the same prob...
Nothing there!
Installed between the Hazard relay and the buzzer and now a working horn!!! Even w/the crappy airbag wheel and all.
Thanks everyone for your help!!!
Old Apr 27, 2007 | 10:10 AM
Speedball's Avatar
Car: 1989 Camaro Iroc-Z
Re: Dang Horn!
I dont even have the horn in my car Not even as much as the center of my steering wheel.. My car sucks..
Old Apr 27, 2007 | 03:04 PM
Car: 91 Camaro RS
Engine: Small Block
Re: Dang Horn!
Yeah thats a problem. Most times i dont even use my horn. I'll just chase whoever down and cuss em out. Works better I think.
Old May 29, 2007 | 01:22 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
Re: Dang Horn!
my horn doesnt work either, i am going to use this thread to see if i can get it back up and running. need it to pass safety
Old Mar 22, 2008 | 04:37 AM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: Dang Horn!
i will be looking today to see if my horn relay is there and replace it
Old Mar 22, 2008 | 01:27 PM
jtreadwell's Avatar
Car: ?
Engine: ?
Transmission: ?
Re: Dang Horn!
Mine didn't work either. Looks like the steering wheel was removed before and someone just pulled the wire straight out of the column. Anybody know how to get around that short of removing the column? So to pass inspection I ran a wire from the horn to a switch inside the car, and from there to a constant hot circuit in the fuse panel. now I just have to reach for the button. I still want to fix it right I'm just not sure how to go about it.
Veaceonee
Sep 29, 2016 08:15 PM
Fox118
Sep 1, 2015 04:07 PM
tc7761
Aug 30, 2015 09:45 AM
Stauf
Aug 24, 2015 08:31 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
