Replacing Sensors (Need Parts and Help)
Old Apr 24, 2007 | 10:35 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I am about to do my exhaust and cooling system and need to replace my o2 sensor, coolant sensor, temp guage sensor. Could someone help me find some of these. I am not sure what to get when buying these parts?
P.S. I am getting Haydens Fan Control kit so IDK if I still need the coolant sensor.
I am getting Hooker Shorties 2460 just need the right 02 for it and wires (Heard NTK was good)
My temp guage doesnt work so I thought I'd replace that too and wires. Thanks for all help.
IF YOU NEED ANYMORE INFORMATION JUST ASK...AS I WANT THE BEST FOR MY CAR.
-FrontWheelDrive BLOWS!
Old Apr 26, 2007 | 07:54 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Replacing Sensors (Need Parts and Help)
Come on guys...ya really dont know how to help on this one? I just dont know exactly what I need. Someone help?
Old Apr 26, 2007 | 10:33 PM
rodie_27's Avatar
Car: '89 IROC convertible
Engine: 355 TPI
Axle/Gears: 3.45? Posi
Are you 100% sure your sensors are bad? I'm not even close to an expert, but some of my gauges/sensors weren't working properly and I discovered that they were simply not hooked up correctly. Are you looking for the under-hood location of your sensors or somewhere to buy them?
Old Apr 26, 2007 | 10:48 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Awesome, I just put those exact same headers in my 87 Trans Am. And yes, I had to replace (actually, replacing since they are still in the garage) the same sensors. I didn't "need" to replace three of those, but I figured I might as well since my car is 20yrs old.
Oxygen senors:
I just went to the autoparts store and got the regular oem replacement. I believe I got a Bosch(sp?) O2 sensor for 82-92 F-bodies. The O2 bung on the driver side header should be same as the oem on the manifold.
Engine Temp Gauge sensor:
This one is between the first two spark plugs on the driver side. This one I didn't have to replace, but I did. Its rather simple. It just a bolt with a nail-like tip you just hook or unhook. Last one you'll need is...
Fan Temp sensor:
This is the exact same sensor on as the engine temp gauge, except that its between the last two spark plugs on the passenger side. I broke this one and had to replace it. This sensor is to activate the second fan when the engine temp reaches 220(I think)...I'll include a pic of this sensor...
Old Apr 26, 2007 | 10:53 PM
HCR13's Avatar
Car: 1987 Trans Am
The coolant temp sensor should be on your intake manifold. On mine, its under the throttle body...
Old Apr 26, 2007 | 10:58 PM
rodie_27's Avatar
Engine: 355 TPI
This controls the gauge reading? My gauge isn't working and this sensor (in the location you described) is missing it's harness. Can I splice some wire between sensor and harness, assuming I find the right one?
I don't mean to hijack your thread, but maybe this will help us both. Thanks!
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I have a single fan.
I would like to replace them so I have correct readings on my e-check. That and so its one last thing I have to buy new. Lol. Have a thing for new parts...no matter how good the stock may be. Thanks.
Go right ahead....HELP FOR EVERYONE!
Old Apr 26, 2007 | 11:07 PM
rodie_27's Avatar
Engine: 355 TPI
Yes, there certainly is something to be said for having things new in working order! I've been having some sensor issues and lots of electrical problems. I think more of my problems are being caused by faulty sensors than I originally thought. If I can figure it out soon, I'll post some remedies. Thanks for sharing the info! And also to HCR13 for answers
Old Apr 26, 2007 | 11:47 PM
HCR13's Avatar
Car: 1987 Trans Am
rodie, I think if you do find the right wire for your temp gauge you can connect it with a new harness. I myself have to go to a junk yard since the harness on the fan switch also pretty much disintegrated (20yrs of heat on plastic takes its toll). I agree, I'd rather replace the oem sensor and connectors. Specially since they aren't "expensive" parts (max $15 for coolant temp sensor...) And the sensor are rather important to the diagnosing from the computer... No prob for the info. I'll take some more pics tomorrow after I (hopefully) have all of them installed. I'm learning along just like you guys...
Old Apr 27, 2007 | 08:15 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I will be going to get my fan motor, hayden total fan control kit, coolant sensor, knock sensor NOW, and temp sensor, and o2. Thanks a bunch. I just thought there might be some aftermarket ones to try...I always see people talking about a heated 02 and a cooler 02...whats that about?
Old Apr 27, 2007 | 04:02 PM
HCR13's Avatar
Car: 1987 Trans Am
I'm not sure. I just got an oem replacement Bosch. I was think about that earlier today, about the temp and the lack of a cat...hhmm...ohwell. Only time will tell, then I'll tell you...
Old Apr 27, 2007 | 09:48 PM
rodie_27's Avatar
Engine: 355 TPI
Man, this has turned into a very helpful, informative thread. Does the Hayden total fan control kit have a website? How much does it cost? I'm having an issue with my temp sensor/s (and gauge) and my fans not kicking on. I just bought a 195 degree thermostat and I'll see what that fixes if anything. That's because all of a sudden my radiator isn't flowing anymore, doesn't leave closed loop. Maybe I should check the temp sensor on pass. side head? If it doesn't seem to be turning out right, I'll look into some alternative. Thanks in anticipation!
Old Apr 28, 2007 | 10:45 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Total Fan Control
The best way to set up your fans.
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
92purpz28
Aug 11, 2015 02:30 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
