testing computer?
Old May 2, 2007 | 01:21 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
testing computer?
is there any way to test the computer while it is not in the car? thanks for the help. -jon
Old May 3, 2007 | 12:55 AM
Re: testing computer?
ttt
Old May 12, 2007 | 12:17 AM
ttt
Old May 12, 2007 | 07:55 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Not a good way. You would need a complete engine simulator.
Do you need to test it or do you need to find out if it's bad? You can always use a different ECM in your car to see if there's any difference between them.
Lou
Old May 12, 2007 | 10:32 AM
well i bought a tpi setup off of someone and they melted through some of the wires in the harness, i wanted to see if i could test it because i wasn't sure if this would hurt the computer any.
Old May 12, 2007 | 04:08 PM
BigBadLou's Avatar
Engine: TPI
Then you can put it in a car that has the same computer. If the car runs the same, the ECM should be ok.
Lou
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
PurelyPMD
May 5, 2016 04:57 PM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
