starter wont turn over
Old May 12, 2007 | 09:31 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
I just put a motor in an '86 z28 camaro. it had no motor when i got the car. it had no key so i had to change the key cyclinder . i have got the motor in now and trying start it and the start wont kick in just clicks. i can jump the start and it will turn over . the lights work and the turn signals work with the key on windshileld wipers work too. So anyone have any idea what could be wrong?
Old May 13, 2007 | 10:23 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Re: starter wont turn over
Low charge in your battery or maybe a bad starter solenoid. Did you install a new battery and starter? If the battery is fully charged, I would have the starter tested at your local auto parts store.
Oops, I just re-read your post and noticed your lights and wipers work. That may narrow it down to the solenoid, but you still might want to check both.
Old May 13, 2007 | 10:54 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Are the wires in the correct spots to the starter? I would also get the starter checked.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Formula_88AE
Sep 3, 2015 01:47 PM
andy74
Sep 3, 2015 08:41 AM
