what do these connect too?
Old Jun 1, 2007 | 05:21 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
hello all, i have a few items that i dont know where they plug into. and would like to know what they are.
i need to know the things i boxed in with red. showed you 3 pics. two of them are close detailed and the other is an overview but all have the red box on what i need to know..
reason why is tryin to find out why my car's fans arnt turning on , replaced the fan switch and then thermostat and this is the 2nd time in bit over a year.
anyways i need find out what theses go to , i took it to a shop around here they had no clue, ive done searches and came up with nothing so please help me
Attached Thumbnails what do these connect too?-bad-day-0089.jpg   what do these connect too?-bad-day-0069.jpg   what do these connect too?-bad-day-0079.jpg
Old Jun 1, 2007 | 07:17 PM
Stephen's Avatar
Car: 87 GTA
Re: what do these connect too?
Pic #2...My bet is the one on the left in that pic, is the relay.
Since mine is a Pontiac, my air intake is on that side, and its a bit hard to see down in there, without pulling the filter box, which means the MAF, and half the air intake, would be loose.
I'm sure a more Camaro knowledgable person will chime in.
Old Jun 1, 2007 | 08:24 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
#3 is a power wire from the battery. It powers aeveral things. I think the ecm is one of them.
Old Jun 1, 2007 | 11:54 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
what does #3 actly power and what are those two pluggs for anyone eles know this answer??? plz help me
Old Jun 2, 2007 | 01:47 AM
Stevo's Avatar
Car: Pair of 92 Z28s
Picture 1 the 2 plugs: those 2 plugs look like connectors for an air pump. Which i see you have headers and it looks like the air system was pulled off. Ill check my car tommaro to see if the plugs look the same as mine(i removed my air pump) but they do fit the right location where an air pump would be.
Picture 2 those are 2 relays, do you have 2 fans?
Old Jun 2, 2007 | 10:04 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
yes i have 2 fans, but they dont turn on ,yesterday my car over heated and my coolant was boiling in the resivor. and my fans wouldnt come on. ive replaced the fanswitch and the thermostat about 2 weeks ago and it rand realy well untill yesterday.
the air system was pulled off by mike chriss and i when we did my exhust, didn't realize that thats what they could be
thanks for the help so far, does anyone know what the thing is in pic #3
Old Jun 2, 2007 | 10:06 PM
BA92GTA's Avatar
Looks like you have some wire tracing to do. I agree with the above post the wire you are showing are for the fan circut. Attached is a web link to a very accurate diagram of your wiring. GO to the link that says "Electrical" and take your time. You'll find the answers to your questions. Good Luck I hope this helps.www.Chevythunder.com
Old Jun 3, 2007 | 12:40 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Small orange wire is the constant wire for the ECM. I no longer have it or the ECM with my 355/carb and everything else works. So I believe it ties to nothing else. Ill check the DealerSeviceManual I have and will chime back If I am wrong.
Old Jul 2, 2007 | 11:12 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
bring this thred back from the dead~
on that note in pic 2 there are two relays for the cooling fans, where can i get the harness that they are connceted to ? ive tryed rock auto advance and pepp boys, where to go?
InfernalVortex
Apr 20, 2021 11:31 AM
bplessy
Sep 30, 2015 12:14 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
