HAZARD SWITCH ??
Old Jun 25, 2007 | 07:30 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
HAZARD SWITCH ??
yes i did a search , could not find what i needed . my hazard switch only works when i press the button in . button will not stay in , o.k. , bad switch .
how to change switch ? anyone know how ? thanking in advance .
UNCLE TOM
Old Jun 25, 2007 | 09:00 PM
randy4762's Avatar
Car: 2010 Camaro 2SS, 1994 Chevy Blazer
Engine: 6.2L, 355TBI
Axle/Gears: 3.42 posi, 3.73
Re: HAZARD SWITCH ??
Tom,
The hazard switch is part of the turn signal switch also. The steering wheel must be removed to service the switch. As well as the lock plate under the wheel.(easier if u have the special tool) Sometimes it is just the detent spring and can be tweaked.
Other times it is all of the plastic is cracked and must be replaced. It is a big job to replace, especially on tilt columns. I have done many and have it down to a half hour or so. I can send you a scan of the factory manual if needed. You didn't say what year you have.......
Randy
Veaceonee
Sep 29, 2016 08:15 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
RacerM
Sep 28, 2015 04:25 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
