A Weird Problem
Old Jun 29, 2007 | 10:17 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
A Weird Problem
When I turn my headlights on, my right running light doesn't turn on. But, when I turn the right turn signal on it works. These are the two orange lights in between my headlights, and they operate as running lights and my turn signals. Just wanted to cut to the chase, and any replys would be appreciated.
Old Jun 29, 2007 | 10:55 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Re: A Weird Problem
hey, not sure of how to fix it but my iroc has the opposite problem... the left turn signals on the fender and the front of the car will light up as the parking lights but wont flash as the signals... so i have a weird issue to lol good luck with fixin it. mabye that could be the same prob as mine. i think i have a loose or broke wire so look for that under the hood. hope that helps. -Matt
Old Jun 29, 2007 | 11:01 PM
Re: A Weird Problem
Yea, I here ya. Its something that bugs me and I am the only that probably notices it anyways. LOL
Old Jul 1, 2007 | 05:25 PM
Re: A Weird Problem
bump
Old Jul 9, 2007 | 10:29 PM
Re: A Weird Problem
bump
Old Jul 10, 2007 | 01:43 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: A Weird Problem
It sounds like you could have lost grounding to that lamp.
Just a guess, w/o having looked at a diagram or anything.
Old Aug 8, 2007 | 04:49 PM
Re: A Weird Problem
bump
Old Aug 8, 2007 | 05:29 PM
nhraformula's Avatar
Car: 2000 formula NHRA
Transmission: 6-speed
Re: A Weird Problem
sounds like this lamp is controlled from two different place one being turn signal switch and flasher and head light switch. obviously the switches are working but you will need to find the relay for the running lights and make sure all connections inside the relay are working along with the wires in the relay connector. problem maybe relay but more than likely the wire from the relay connector to the lamp or the wire in the connector that should be hot all the time
Old Jan 21, 2010 | 07:00 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
Re: A Weird Problem
I have the exact same problem. Annoys the crap out of me! Still have'nt gotten it fixed. Need help as well!!!!!
Old Jan 21, 2010 | 09:13 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: A Weird Problem
Have you replaced the bulb? I'm 90% sure that those are double filament bulbs, meaning there is a filament for each function, running/parking lights and turn signals.
Old Jan 21, 2010 | 10:04 PM
Brother Al's Avatar
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
Re: A Weird Problem
Its likely a short in the wiring somewhere. I posted a similar issue I had with my old '86 Firebird, couldn't find it. Mother Nature showed me the source tho.
https://www.thirdgen.org/forums/elec...res-check.html
Old Jan 22, 2010 | 12:28 PM
Engine: 350 S/B
Re: A Weird Problem
I pulled the bulb on my passenger side front running light and both filaments are good. Thinking it's in the wiring now.......?
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
