Uh-Oh. Wire Touched that Shouldn't
Old Jul 12, 2007 | 12:55 AM
graywolfman's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305cid 4BBL E4ME Quadrajet
Alright here's my problem. We rebuilt my carburetor (E4ME computer controlled) on my 83 Firebird w/a 305 4bbl. As we were adjusting it we had to use the tach wire coming off the distributor, and it shook with the car, fell and grounded out. It killed the car and we removed it from its ground-out then started the car. Does anyone know if that would mess something up, or should I not worry about it. I have been having strange electrical issues lately, but I do not know if that is coincidence or if that wire grounding out would have caused any problems.
If anyone could help it would be appreciated.
Last edited by graywolfman; Jul 12, 2007 at 12:59 AM. Reason: Automerged Doublepost
Old Jul 12, 2007 | 01:08 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Uh-Oh. Wire Touched that Shouldn't
If it didn't blow a fuse or burn a fusible link, there's probably nothing to worry about.
Old Jul 12, 2007 | 01:30 AM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
go non cc...my buddy did w/ his 86 t/a and it made a world of difference he has no emissions at all on his car now
Old Jul 12, 2007 | 09:58 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
That wire is constantly grounded by the points in the distributor - the grounding sends a spark from the coil to the spark plugs.
So no worries, this did not cause any damage, you are perfectly fine.
Hope this helps.
Lou
Old Jul 12, 2007 | 10:58 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
By the what?
Old Jul 12, 2007 | 02:31 PM
BigBadLou's Avatar
Engine: TPI
The points. On the distributor cam. Carbed engines still used points and centrifugal weights back then. Seems like ages ago.
Lou
Old Jul 12, 2007 | 02:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not in 83 they didn't. Points went out of fashion in 1975.
Old Jul 12, 2007 | 02:37 PM
BigBadLou's Avatar
Engine: TPI
The carbed 1988 460 bigblock I have at home still has points and weights. It's a truck engine, though.
Lou
Old Jul 12, 2007 | 02:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Also not the original distributor, then.
Old Jul 17, 2007 | 02:30 PM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
mine has a hei distrubutor, electronic ignition
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 07:57 PM
