HELP! Fuse 11 (interoir lights) keeps blowing! in shop costing $75/hr!!
Old Jul 23, 2007 | 09:37 PM
briwar454's Avatar
Car: 1985 Trans Am
Transmission: THM 700-R4
Axle/Gears: Stock
So my tech is having trouble find out why fuse 11 keeps blowing. the fuse blows as soon and the fuse hits the fuse box. This fuse controls power locks, interior lights, lighter, horn, trunk open, etc.
he said he spent an hour looking for simple problems and found none.
Has anyone run into this?
The only thing I didn't check before it went to the shop was the lighter. if this $2 part is the problem, I'm gonna throw myself off the near pier!!
thanks for reading!!! thanks for the help in advance!!!
Old Jul 23, 2007 | 10:01 PM
spr250's Avatar
Car: Divorce stole it
Engine: Divorce stole it
Transmission: Divorce stole it
Axle/Gears: Divorce stole it
Re: HELP! Fuse 11 (interoir lights) keeps blowing! in shop costing $75/hr!!
Ive had the cigarette lighter problem before in another vehicle, actually now that I think about it, my old 84 z28. I just diconnected the wires and taped them off. Another thing is you might have a grounding wire. do a continuity check for high resistence on grounds/hots and voltage drops for the hots. Also try a different cig lighter, alot easier and just pull one off another car that fits. I would also disconnect everything it controls put a fuse in and start plugging items in until it blows. Just as a recap, in my experience its always been the lighter or lighter plug-in. Hope this helps, let me know.
Old Jul 27, 2007 | 03:10 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Have you done any work to the car recently ??? If the fuse is blowing the second it hits the box than there is most likely a power wire touching the body ( ground ) somewhere. Or perhaps a penny in the cig lighter ??
I did some work to my cluster one time and once everything was back together the Accessory fuse blew out every time I hit the rear hatch release. It turns out that the power wire for the hatch release got pinched between the column bracket and the dash housing when I was working on the cluster. I'm saying this because you might have done work in one area of the car that seems totally unrelated to the problem circuit - but it has effected the wiring in a (bad) way !
My guess ( if there's no penny in the cig lighter! ) is that one of the accessories running from this fuse has it's orange wire touching the body somwhere.
Here's a copy of the ACC fuse from an 86 Firebird. Your 85 must be similar !
Good Luck !
Old Jul 27, 2007 | 03:50 PM
briwar454's Avatar
Car: 1985 Trans Am
Axle/Gears: Stock
i don't even want to tell you guys what the problem was...
Old Jul 27, 2007 | 04:04 PM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
well what was it?????????????????????
now you have to tell
Old Jul 27, 2007 | 04:08 PM
spr250's Avatar
Yea, no teasing, what was it
Old Jul 27, 2007 | 04:14 PM
briwar454's Avatar
Car: 1985 Trans Am
Axle/Gears: Stock
a small piece of metal in the lighter...cost me $60 dollars...boo... and yes, i'm a idiot.
Old Jul 27, 2007 | 08:21 PM
John in RI's Avatar
I was close !!!
Old Jul 27, 2007 | 09:11 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Live and learn. That`s how many of us know what we know, been there, done that.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
