Fuse Keeps blowing!
Old 08-17-2007, 09:46 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Fuse Keeps blowing!
Just about anything I plug into my cigarette lighter (cell phone charger) blows the fuse to the accesories. Anyone else have this problem?
Old 08-18-2007, 01:48 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Fuse Keeps blowing!
Yes, and its usually a shorted wire connected to your cigarette lighter. I dont remember the steps to fix it but I remember pulling out my cigarette lighter and resolding the wire.
Old 08-18-2007, 08:50 AM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Thanks, I'll have to try that.
Old 08-18-2007, 09:49 AM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
I had that problem. Turned out the lighter case or whatever was causing it because it was so rusty. If yours is rusty, sand it off or get a new one. Don't buy those newer style lighters because they don't fit. But Im not saying this is your problem...
Old 08-22-2007, 12:35 AM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Its not only the lighter, its my cell phone charger or just about anything that I plug into it. The weird thing is that the fuse doesn't blow right away, it blows whenever I push the charger plug or whatever to the back of the socket. If I just plug in the charger half way I can get power to the charger but if I plug it all the way in it blows the fuse.
Old 08-22-2007, 04:05 AM
IrocZ85's Avatar
Dont forget your horn and something else is on that same fuse but as I smoke I have found a rusted out lighter housing to be the main case, again try and sand it clean or replace
if its happening shortly after using the horn though check the wires under the cap first as they almost always have problems
Old 08-22-2007, 11:35 AM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Thanks, I'll try that and see what happens.
Old 08-22-2007, 11:41 AM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
I know this sounds stupid but make sure you have the correct fuse. If its suposed to have a 20 amp fuse and you have a 15 amp fuse in its place then putting something else on that ciruit will blow the fuse.
3rd gen money
10-11-2019 09:57 PM
thunder57
11-07-2015 02:28 PM
Fanatic1074
10-02-2015 03:47 PM
lanceflame44
09-25-2015 12:28 PM
90formulaVortec
09-03-2015 09:26 AM
Quick Reply: Fuse Keeps blowing!
