The ever popular VATS questions.....Need a bit of help again.
Old Aug 21, 2007 | 07:42 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Transmission: Automatic
Axle/Gears: stock(what could be better!!)
Ok...I am at a standstill.....I need to know exactly where my vats relay(or vats box) is located at....I have a 1991 Pontiac Firebird v6, 5 speed....I have looked for it but still have not found it. Somebody please help, I have heard several locations, but still havnt found it. ANYBODY???
Old Aug 21, 2007 | 09:52 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
Re: The ever popular VATS questions.....Need a bit of help again.
The VATS starter enable relay is behind the left hand kick panel. It's screwed to the body. The VATS module is behind the dash screwed to the plastic duct coming from the plenum that directs air to the driver's vents.....
See attached images:
STARTER RELAY
VATS MODULE
Old Aug 21, 2007 | 10:37 PM
Stephen's Avatar
Car: 87 GTA
I understand where the Relay is, but the Module diagram, is too close up to identify it's location.
Old Aug 21, 2007 | 11:21 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
just start ripping stuff out! thats what im about to do
Old Aug 22, 2007 | 08:03 AM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Yea, they don't show the location as well as they do with the starter relay.. But, it's not that bad.. The diagram shows the shape of the thing..
You have to remove the instrument panel to get at the VATS module.. It's on the air distribution ducts from the plenum. Once you know that, when the instrument panel is is out, you can't miss the module.
Old Aug 22, 2007 | 11:54 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
that is incorrect my friend...i cannot see the thing at all. all i see is a big plastic piece....i still cannot locate the vats module. any other advice?
gta892000
Aug 11, 2019 11:16 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
Linson
Sep 21, 2015 01:08 PM
sahlomonic
Sep 20, 2015 07:15 PM
383cam
Sep 9, 2015 06:01 AM
