Cleaning
Old Sep 21, 2007 | 01:05 PM
Speedball's Avatar
Car: 1989 Camaro Iroc-Z
Cleaning
I have a problem with my eletrical system. The battery is being drained fairly quick and I have no idea why. The engine bay looked like crap when I bought the car and I have spent hours cleaning it.
I would like to try to clean and maybe even replace the different connections as well. I am pretty sure that I cant just poor some nice hot water on the connections and use "kaboom" soap (that guarantees that everything will be as new...) to clean.
what should I do?
Old Sep 21, 2007 | 01:07 PM
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
Re: Cleaning
Powerwasher.
Old Sep 21, 2007 | 01:18 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Re: Cleaning
ls1 swap.
Old Sep 21, 2007 | 01:25 PM
shawnc16's Avatar
Re: Cleaning
HA! Or maybe an LS7 just for good measure and a smile...
Old Sep 21, 2007 | 01:51 PM
Speedball's Avatar
Re: Cleaning
are you two stalking me?
I was thinking more of spending maybe 10 bucks trying to improve things.
Old Sep 21, 2007 | 01:54 PM
MattODoom's Avatar
Car: '88 G T/A
Re: Cleaning
No, I'm just here to out-do Shawn, as he stated in a different thread. That's really the purpose of my life.
Old Sep 21, 2007 | 01:55 PM
shawnc16's Avatar
Re: Cleaning
Im just stalking you. hahahah jk
Old Sep 21, 2007 | 02:03 PM
MattODoom's Avatar
Car: '88 G T/A
Re: Cleaning
So the truth finally comes out.
Old Sep 21, 2007 | 02:23 PM
Speedball's Avatar
Re: Cleaning
I just went over a couple of the relays and i just unplugged them and connected them again. However. I did figure out that the ground from the battery was kind of loose. Could that be the reason for some of the problems?
Old Sep 21, 2007 | 05:29 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: Cleaning
A loose battery ground can give you problems, don't know what kind you had though..
Provided you disconnect the battery you can use soap & water to wash the contacts any way you like, just flush well with clean water afterwards & use compressed air to make sure they are completely dry (inside) before applying power.
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
WhteRbt
Sep 21, 2015 09:48 AM
