Good alternator not charging.
Old Nov 4, 2007 | 03:33 PM
YigyYo's Avatar
I brough my alternator in to get tested and results were fine, in disbeleif I purchased a new alternator and installed it and same thing. Ill charge my battery to 12.60 and when I start my car voltage drops to around 11.98.
I've read through the message boards and am starting to beleive it has something to do with my fan not working because my fan stopped working around the same time my alt stopped putting out a charge.
While im waiting for my fan switch to arrive Im looking for any help incase that is not the problem.. What about the fan fuse? is the fan fuse located with the fuses under the steering wheel?
Oh and for now my fan is running off a switch.. I pulled out the fan relay and hard wired the 2 main wires to a switch.. Since my fan works through a switch doesnt his mean my fuse should be ok?
Im new to most of this stuff so bare with me!
My car is an 88 firebird TBI code E.
Old Nov 4, 2007 | 03:44 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: Good alternator not charging.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
This link should help you out tracking down your problem.
Old Nov 4, 2007 | 03:54 PM
YigyYo's Avatar
Those charts are chinese to me!
Old Nov 4, 2007 | 04:01 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
check your fuseable links . there should be 3 orange wires together near the battery . feel the wires if one is blown/open you will know . they can be repaired/spliced .
Old Nov 4, 2007 | 04:26 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Make sure that the Alternator is getting the reference voltage! Without it, the regulator will not function and the alt wont charge.
What car/alt do you have?
Old Nov 4, 2007 | 05:29 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Similar situation for me a while back. Cooling fan wouldn't work, nor would the HVAC blower. There was no reference to the alternator. The ignition switch failed in such a way that there was no accessory power out of it, including the alternator sense voltage.
Old Nov 5, 2007 | 08:10 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I can't believe nobody can give him a straight answer. *shakehead*
Yes, YigyYo, you are right, the fan relays and alternator "sense" wire are on the same fuse, it's marked "FAN" under your dash.
That sounds like your culprit.
Lou
Old Nov 5, 2007 | 09:03 AM
Toehead's Avatar
Lou
What do you mean by that?
Old Nov 5, 2007 | 09:16 AM
YigyYo's Avatar
Thanks Lou! does the fan relay have to be in tact in order for the alternator to work? the reason I ask is because I took it off for now. However I have a new fan switch comin soon, ill hook it up, reinstall my fan relay and check the fuse. Ill let ya know of the outcome.. just gotta wait a couple of days for my switch.
Old Nov 5, 2007 | 11:05 AM
BigBadLou's Avatar
Engine: TPI
No need for the relay to be connected. As long as the FAN fuse is ok, you should have power to the alternator wire and it should be charging.
Lou
Old Nov 5, 2007 | 12:42 PM
YigyYo's Avatar
WOW... A broken fuse this whole time.... I poped in a new fuse and now my battery is receiving a charge! and when I put my relay back together my fan will probably work too.... I could of sworn I checked the fuse.. oh well. Thanks again Lou!
Old Nov 6, 2007 | 08:35 AM
BigBadLou's Avatar
Engine: TPI
No problem, that's what we're here for!
Lou
dcd2236
Exterior Parts for Sale
Aug 19, 2018 02:27 PM
Navy8125
Aug 22, 2015 07:13 PM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
