91 firebird factory alarm will not shut off
Old Nov 19, 2007 | 09:41 PM
sly_sloth's Avatar
Hello,
First time poster... long time reader....
I have a pain in ht ebutt problem wiht my 91 firebird v6....
It all started this summer when I lost the vats key and was left with just the master/valet key what ever you wanna call it.
I did not know the resistor value for my key so I by passed the ignition system and spliced in different resistors until I found one that worked.... #10 if I recall correctly.
I have used the master key as my main key with no problems until now... I left my car sit with the lights on over the weekend and when I tried to jump it the alarm engaged and will not shut off... I disconnected the siren but the lights still flash each time I open the doors and remain flashing when I turn the car off.
I tried disconnecting the battery but the alarm immediately engages when I reconnect it. Is there any way around this problem other then getting a new vats key with the resistor chip in it and reconnecting the ignition to the vats?
Any help would be greatly appreciated.
Old Nov 19, 2007 | 10:29 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 91 firebird factory alarm will not shut off
VATS has nothing to do with any lights or sirens. THe vats system just keeps the car from cranking for a few minutes. That's it.
Old Feb 2, 2009 | 05:05 PM
bhoyer92rs's Avatar
Did you ever get this fixed. My Camaro just started doing the same thing. bhoyer@comcast.net
Thanks,
Brian
colton_carlson
Mar 8, 2019 12:21 PM
Stauf
Aug 24, 2015 08:31 PM
CORV3TT3
Aug 23, 2015 11:26 AM
wayshegoes
Aug 17, 2015 12:00 PM
Fronzizzle
Aug 9, 2015 01:15 PM
