Headlights stuck in high
Old Nov 23, 2007 | 03:02 PM
1991Formula350's Avatar
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
I had turned my high about 2 years ago and I can not get them to go back to low. I tried playing with the tilt wheel on the steering and nothing. Has anybody else had this problem? A '91 Formula. Andrew
Old Nov 23, 2007 | 04:14 PM
xChAoSx's Avatar
Car: 1987 Firebird
Re: Headlights stuck in high
Unscrew the cover the covers the underneath the steering wheel area. Its the big plastic piece that covers everything from your feet. Ok now get underneath there and look for the rod that controls your high beams and low beams. You can move the blinkers handle when your looking for it(the rod) so you can find it faster. Its should be located right down the steering column. At the bottom of the rod theres a plastic piece (This is the switch) The rod is supposed to slide right into it. In your case the switch might be broken or the rod might have slipped out of it. If the rod slipped out of it then you should push the plastic piece down and slide the rod back into the "switch". By pushing down you should hear a click, when you hear that your high beams should be switched off.
I had the same problem for a while. I got tired of blinding people on the road so i investigated and figured it out myself. Ill try to post of pictures.
Any questions? Hope this helps.
Old Nov 23, 2007 | 04:56 PM
docs89gta's Avatar
Car: 89 GTA Trans Am
I had the same problem before. Is your tilt wheel loose? Mine was pretty bad and what i had to do, was put the wheel straight like i had no tilt and then push forward a little on the left side of the wheel and then pull the high beam switch and that got mine to go off. I have since fixed the tilt problem and all works fine now.
Like the above poster said though, the rod may have come out. Just throwing some more advice out there for you.
Old Nov 23, 2007 | 08:37 PM
xChAoSx's Avatar
Car: 1987 Firebird
I took a picture of this today. I had to do some things under the wheel, so decided to undue what i fixed a while ago and show you what might be going wrong with your high beams switch. This goes for anyone else who might be having this same problem. It really easy to put back in the hole, i figured i'd show you what it looks like and maybe save you some time searching and figuring out how to do this fix.
*note*
This is picture shows the rod and the switch when the rod has slipped out. This does not show a broken switch.
Old Nov 23, 2007 | 09:12 PM
Guy In A 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
I had the same problem when I bought my car- the high beams were stuck on . . reading these forums before I even became a member helped a good deal.
My problem was the switch had moved downward over the years from use, and the rod simply couldn't go down far enough to push the switch. So, after 2 hours of trying to fix it how the Chevy service manual stated, (Its a royal pain trying to work under there) I cut up a pencil top eraser and stuck it in switch hole pictured above. Inserted the rod and it worked like new. That was several months ago and its still working.
Oh, be careful not to go tugging on the rod too much or it might pop out at the end of multi-function lever. I did that. . . twice. . .
Hope this helps.
Old Nov 23, 2007 | 09:48 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Try this article that I wrote some time ago. It has some pictures too.
Adjusting the Hi/Lo beam switch
Hope this helps.
Lou
Old Nov 24, 2007 | 09:32 AM
Car: 1992 Formula
Axle/Gears: 3:42
Thank you guys! I am going to go out this afternoon and do it as I have the afternoon free. Thanks! Andrew
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
corey8084
Sep 17, 2015 02:56 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
