wiring harness problem
Old Jan 1, 2008 | 03:29 PM
killacamaro's Avatar
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
ok so i went to my boys house who has an 88 iroc that he wants to get rid of. he sed that the engine wireharness melted and needed to be replaced. i went inside the car and saw these receipts. can you tell me what they mean and if this is the area where his wiring harness melted. thanx
they did a diagnostic labor for the cooling fan INOP. i have no clue wat that stands for.
performed harness repair for fan relay.
sw temp sending switch labor.
if i could get sum scoop on theese things and what i could do to fix this 88 iroc thanx
Old Jan 1, 2008 | 05:01 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: wiring harness problem
Thereis no way of knowing for sure with those receipts.
You need to inspect the harness yourself for damage.Not too much work involved in that,just do a visual inspection from top and underneath.
Is the car not running?
battery still conn.?
Old Jan 1, 2008 | 05:03 PM
Car: 88 IROC-z
Engine: LO3 V8 305
the car has been sitting for 3 years. and the batt still connectd, he says it doesnt run because of the harness. i havent tryd to do anything. what do those receipts mean tho. and is it worth taking from him and putting in a new harness?
Old Jan 1, 2008 | 05:13 PM
I have no idea for sure what those receipts mean other than someone obviously paid to have the car checked out.
Is your friend just giving this car to you?
If so,then yeah it would def. be worth getting from him.If you can't get it fixed just part it out.There plenty of folks looking for Iroc parts.
Old Jan 1, 2008 | 05:30 PM
Car: 88 IROC-z
Engine: LO3 V8 305
well he givin me the car for 500 bux, everything else on the car is in great/mint shape. i can get a harness for 100 bux. so im thynkin do the wrk myself and see wat goes on.
if a harness is bad, is htere a way to still use the car? or even try to start it?
Old Jan 1, 2008 | 05:37 PM
Well,in that case I would def. get it.
Drag it home then just do a careful visual inspection of the complete engine bay wiring before removing it.If its melted somewhere it shouldn't be to hard to find.It may even be repairable without the expense of another harness
Old Jan 1, 2008 | 05:40 PM
Car: 88 IROC-z
Engine: LO3 V8 305
i was told not to splice n fix. they sed replace the whole thing. he forgot why it meltd but seems to me 2 wires were touching that werent supposed to and over circuited.
* Also if the harness is melted everyhting else should work in the car correct? like electronics and stuff?
Old Jan 1, 2008 | 06:05 PM
you can splice/fix the harness if its only minimal damage like 2 wires.
If you're talking major stuff like near the pass. side where the harn. goes into the ecm,then no don't try splicing and fixing that,thats a whole bunch of wires and a few are the same color so it would be difficult to repair and $100 for another harness would be the way to go IMO.
And not everything may work in the car,depends on what was melted.
For example,if the wires to the starter were melted NOTHING in the car will work.
Old Jan 1, 2008 | 06:23 PM
Car: 88 IROC-z
Engine: LO3 V8 305
well to me it seems from those reciepts it has sumthing to do with the fan relay. i hope that is wats wrong cuz that will be an easy fix.
*wat Is --> " SW TEMP SENDING SWITCH "
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
