Help with Identifying Modules?
Old Jan 29, 2008 | 06:42 PM
Firebird_dave7's Avatar
Car: 1987 Firebird
Engine: Present=350/4brl, Future=455 H.O.
Transmission: Present=700R4, Future=Richmond 6Spd
Axle/Gears: Now Stock, Later 3.73
I would like have help with the identification of a few items on a 1987 Firebird 5.0 LG4:
1. A Black Box 3"X5"X1" With the Letters AC on it it is mounted on the passenger side right under the pouch.
2. Is what looks like a aftermarket piece but could be a replacement this is 3"X2.5"x.75" and is yellow and has the tag that says 4 Out Buffer.
3. The 2 relays that in the battery area, 1 is right next to the radiator and the other is by the fender.
4. This really isnt a queston but a request but can someone give a link to where all the wires into the fuse block go and are if possible.
All Help Is Appreciated!!!!1
Old Jan 30, 2008 | 05:14 AM
Car: 1987 Firebird
Re: Help with Identifying Modules?
Any help at all?
Old Jan 30, 2008 | 11:03 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
#1 What wire colors go in the box?
#2 Sounds like the VSS buffer for the speedometer.
#3 There are many relays in the engine compartment. 2 for the headlights, 1 for each electric fan (if equipped), 1 for fuel pump (if equipped) etc. What wire colors do those relays have?
#4 Try our page with diagrams: http://www.austinthirdgen.org/index.php?pid=19
Hope this helps a bit.
Lou
Old Jan 31, 2008 | 08:45 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Sounds Like the Cruise Control Module,..............
Old Jan 31, 2008 | 04:46 PM
Car: 1987 Firebird
Lou
Thats where i got my diagrams from but i need a Full Fuse Block Diagram
Old Jan 31, 2008 | 05:29 PM
BigBadLou's Avatar
Engine: TPI
You will need to follow each specific diagram for wire colors for each fuse. I haven't seen a specific diagram of the fuse box wiring.
Lou
Old Jan 31, 2008 | 07:12 PM
Car: 1987 Firebird
Dang, well all right then.
thanks
Old Jan 31, 2008 | 09:29 PM
BigBadLou's Avatar
Engine: TPI
Sorry for the bad news but that's the only way it can be done right now (unless somebody compiled a nice diagram on their own).
Good luck on your quest and don't forget that plentiful cussing makes work go faster.
Lou
InfernalVortex
Apr 20, 2021 11:31 AM
dusterbd
Sep 29, 2015 08:40 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
Linson
Sep 21, 2015 01:08 PM
