headlights won't come up until I hit a bump
Old Feb 6, 2008 | 06:35 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I'm not sure if this issue is in the switch or the headlight units. Sometimes when I turn on the headlights, they don't pop up until I hit a bump in the road and jar something loose. Any ideas?
Old Feb 6, 2008 | 11:12 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: headlights won't come up until I hit a bump
Yes, get ahold of Lon at http://www.top-downsolutions.com/ He's a firebird headlight expert and he's nearby to us in SoCal.
Old Feb 6, 2008 | 11:59 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Problem:
Originally Posted by 89******bird
...Sometimes when I turn on the headlights, they don't pop up...
Solution: TDS 209280 Deluxe Headlight repair kit.
http://www.top-downsolutions.com/pro...products_id=87
Lon
Old Feb 7, 2008 | 12:06 AM
brandotron's Avatar
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
I can vouch for Lon's headlight repair kit. Fixed my driver's side headlight with NO problems. Great product. I've never met the guy, but he knows what he's talking about.
Old Feb 7, 2008 | 09:16 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
This might be actually an electrical problem, not mechanical.
Sounds like loose wiring or components.
The healight motors are controlled by a "black box" on the firewall, right by the windwhield wiper motor. Also, each headlight has another separate relay (usually close to the headlight). I'd check those out. Turn on the headlights and if they don't pop up, give the black box and relays a whack or wiggle the wires. If it corrects the problem, it's a bad connection.
Hope this helps.
Lou
Old Feb 10, 2008 | 02:17 PM
Stephen's Avatar
Car: 87 GTA
Yep. If it is the control box, and most likely it is, the lights will come up after hitting a bump. I've been through that before.
If your lights won't come up, pop the hood, and tap on it the motor control box on the firewall. It they pop right up, it's the control box. I swapped mine out after going through this, then rebuilt my first one as a spare.
Old Feb 10, 2008 | 03:58 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
i ordered that kit from lon and it works great... lights come up.. problem is mine don't go down.. and ive replaced the control box..
Old Feb 10, 2008 | 05:30 PM
lonsal's Avatar
Problem: Headlights won't go down. Solution: blown tail light fuse.
Lon
nova983
European Region
Nov 2, 2015 12:15 PM
sylentnite
Sep 9, 2015 02:55 PM
Fronzizzle
Sep 8, 2015 12:10 PM
luvofjah
Sep 3, 2015 07:08 PM
andy74
Sep 3, 2015 08:41 AM
