Turn Signal Indicator
Old Feb 12, 2008 | 07:10 PM
Dave_Knight's Avatar
Recently acquired a 1984 Pontiac Firebird Trans Am. Driving it on the way home, the driver's side turn signal would stay lit when used, and the turn signal indicator would also stay lit. The passenger side indicator would blink normally for both.
I knew someone who gave me an out of the box flasher unit. I changed it out from the old one. Now both exterior turn signals flash like they are suppose to; however, both of my dash turn signal indicators will not light up and blink. I do hear the click, but no lights.
Can anyone help me diagnose?
Thank you for any assistance.
Old Feb 12, 2008 | 07:58 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Turn Signal Indicator
sounds like turn signal switch assembly wear/failure
or flasher socket wires problem, loose wire/socket
good luck
Old Feb 12, 2008 | 08:39 PM
Looks like the driver's side turn signal needs to be replaced, it's a lot dimmer then the passenger side...could this be the problem?
Old Feb 12, 2008 | 09:22 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
The turn signals run off of resistance. They want to see X amount of voltage across the circuit, and if it doesn't, they operate funny. If one bulb is dim, definitely try replacing it. If it stays dim with the new bulb, then you might want to check for shorts, other burned out lights, anything.
Old Feb 17, 2008 | 08:37 AM
Ok, so now that I have my car street legal I was driving down the road for a test, and my passenger side indicator started blinking normally. My driver's side still dosen't show up at all. Thinking...loose connection or burnt out bulb??
Old Feb 17, 2008 | 10:45 AM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Check for a bad ground. Quickest check is to run a jumper wire to a good chassis ground & connect to the light socket. Test your signals & bet this will cure your gremlins.
Good Luck,
COrky
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
skeltor
Feb 2, 2016 10:37 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Randomtask2
Sep 7, 2015 05:06 PM
