Pics of a few relays, modules, and wires.
Old Feb 15, 2008 | 04:41 PM
Firebird_dave7's Avatar
Car: 1987 Firebird
Engine: Present=350/4brl, Future=455 H.O.
Transmission: Present=700R4, Future=Richmond 6Spd
Axle/Gears: Now Stock, Later 3.73
And can anyone tell me what they really are and if i need them. Its a 1987 LG4 Firebird, with the LG4 swapped for a carb'd 350 and was wondering what i should cut and take out while i have it still torn apart and the dash out? its on cardomain
link
http://www.cardomain.com/ride/3008689
Old Feb 15, 2008 | 04:48 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Re: Pics of a few relays, modules, and wires.
Pics aren't viewable without logging in?
Old Feb 15, 2008 | 06:59 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
The only thing that I can see that black box being is the cruise control unit. Was it attached to the large black box under the dash near the ECM? If it was, than it is cruise control related and would be needed if you want cruise control. Not sure about it being the cruise box though.
Old Feb 15, 2008 | 08:07 PM
Car: 1987 Firebird
Well im taking Cruise control out of my car, and it was mounted by the ecm, on the outside of dash behind the first passenger dash panel.
Old Feb 16, 2008 | 08:19 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Sorry for the wrong information, I guess thats what happens when I try to take a guess about a firebirds setup . I really only know camaros
Old Feb 16, 2008 | 08:58 AM
deadtrend1's Avatar
the black box looks aftermarket. maybe something that goes along with the alarm. I don't remember seeing it in any of my thirdgesn over the years.
Old Feb 16, 2008 | 05:11 PM
Car: 1987 Firebird
Well considering the wire into it has original colors i am guessin it isnt aftermarket.
Old Feb 16, 2008 | 06:13 PM
Aaron_SK's Avatar
The box stamped 'AC' is the cruise control module. IIRC the brown wire is the VSS, and the rest go to the cruise diaphram under the hood.
If you don't want your CC, remove the unit, and tie the harness out of the way. There's no harm in leaving the wiring for the cruise, as long as you mark it so you don't mix it up the next time.
The yellow box is the VSS buffer. The yellow and purple lines go to the tranny, the brown goes to the ECM, and the others are probably speedo. If you are going to retain either your ECM, or your stock gauges you will need it.
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
Gunsbee
Sep 7, 2015 07:10 PM
Glowsock
Sep 6, 2015 06:40 AM
middian
Sep 5, 2015 01:42 AM
