rpm's jump up and down, then car shuts off. any suggestions?
Old Mar 3, 2008 | 06:19 PM
halfan89ta's Avatar
ok so my problem started when i was driving to tampa, all of a sudden my rpms dropped from 2200 to about 500 and did it about 3 times and the engine cut off. the lights would dim everytime the rpm's fluctuated. i tried to start it back up and turned over fine but the rpm's immediately droped and the engine cut off again. the only way i could keep the engine going is if i would hit the gas but i would have to let off and hit the gas again repeatedly and even then it would only hit about 2000 rpm's and when i let off it would shut off once again. if i held the gas pedal i would get no reaction. i tried replacing the fuel filter and that didnt help. next i tried the TPS and that didnt help either. a few people suggested the ignition. i replaced the ignition module and a slight difference but still the same prob of jumping rpm's then the cut off. they also suggested the coil and/or computer, but before i go spend money on other parts (since i am on a budget) is there anyone that has had these same problems and knows the solution?
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
