O2 sensor location questions??
Old Mar 10, 2008 | 01:33 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
I just did a quick search and did not find what I was looking for.
I am wondering if I can move the O2 sensor in my '88 GTA from the drivers side header further down the exhaust pipe so it picks up the readings from both sides of the motor? Would this cause any problems? Why is the O2 sensor currently located only in the drivers side header, obviously it doesn't make adjustments to the drivers side only, so what couldnt I move it further down??
Any help would be great, thanks!
Old Mar 10, 2008 | 06:01 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: O2 sensor location questions??
I have heard that the 1-wire (non-heated) O2 sensors need to be close the the exhaust port in order to get hot enough to read correctly. I'm not saying it will or won't work, just one thing to consider.
Old Mar 10, 2008 | 09:33 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That is the reasoning, but then my 3.1 V6 has the single wire O2 sensor in the Y-pipe, just prior to the cat.
Old Mar 11, 2008 | 09:33 AM
speed88's Avatar
Engine: 383
I cant see the exhaust being that much cooler further down in the y-pipe. Especially considering that it comes directly underneath the oil pan, with hot oil inside.
My idea was too place it just after the two headers meet in the y-pipe. Can anyone confirm for sure if this is a bad or good idea??
Ward and Al Hasse, thank you for your replies!
Old Mar 13, 2008 | 08:24 AM
speed88's Avatar
Engine: 383
No one else has any thoughts on this???
Old May 16, 2011 | 01:24 AM
Red-gt'r's Avatar
Resurrection
Did you ever end up doing this or finding out if it would work? I just did what you mentioned here and I'm wondering if it'll work/run properly. I think it will be alright since it's reading a ratio not a level but I'm not 100% sure.
Old May 16, 2011 | 04:49 AM
oramac91's Avatar
that where its should be.
Old May 16, 2011 | 06:12 PM
torque_is_good's Avatar
Originally Posted by Red-gt'r
Resurrection
if you have headers, keep it as close as you can. if you want to run it to the y-pipe then convert to a heated O2.
rhetorical question- what is the purpose of the O2 sensors?
now, let's say that your readings are wrong and the engine runs rich, sure, it will smell and get terrible mileage. Now let's look at the other spectrum and say you run too lean................
get my point?
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Rustyweb7
Aug 9, 2015 03:05 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
