name this plug???
Old Mar 13, 2008 | 07:00 PM
ironleg's Avatar
Car: 1988 iroc z28
Engine: 357ci
Transmission: 4sp auto
Axle/Gears: stock for now
name this plug???
ive got an 88 iroc and in swaping the engine i gess i didnt mark everthing and cant find a place for this plug 1 wire is tan or light brown with a white traser the other is orange its on the back right side of the motor i cant find where it goes can any one help??
Old Mar 14, 2008 | 09:42 PM
ironleg's Avatar
Car: 1988 iroc z28
Engine: 357ci
Re: name this plug???
no one knows where this plug goes to do we need more info??
Old Mar 15, 2008 | 08:38 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
from your pic. it looks like lt. side ( drivers side of eng. ) . if so i would say it's oil press/fuel press. lead . switch is above oil filter . ?????????????
Old Mar 15, 2008 | 09:27 AM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
I think Uncle Tom is right. http://www.austinthirdgen.org/mkport...ine_wiring.gif
Old Mar 15, 2008 | 09:50 AM
ironleg's Avatar
Car: 1988 iroc z28
Engine: 357ci
it comes out of the big wire harnes that runs across the back of the engine and is on the driver side ive got the oil psi taken care of so it must be the fuel psi switch????
Old Mar 15, 2008 | 10:01 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Yes, this is for the oil pressure fuel pump switch. Depending on what you're swapping in, you might/mightnot need this one.
Lou
Old Mar 15, 2008 | 11:16 AM
LOWRS's Avatar
Car: 92 RS
Engine: LO3
There were a couple configurations of this switch, one w/2 wires, one w/3. Since you have the two-wire plug, it's safe to assume your'e talkin' about the oil gauge working. The purpose of the switch is to cut off fp power in the event the oil PSI drops below 6lbs. The switch is on a boss just above the oil filter, and, if you're keeping the circuit intact, you need it. There are ways around that, though, if you don't have the provision for the switch on yer new motor(is that a rat?).
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
