Installing CB Radio... Few Q's about where to run wires
Old Apr 28, 2008 | 06:26 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, I had a small Cobra CB lying around, it's not the big one with all of the controls on a different piece, they're all on the microphone. Anyway, I was wondering how I would run the antennae wire to the back, I don't want to drill any holes.. I was going to run it to the hatch, and put the wire between the hatch, and the seal. Would this be alright? How would I get it back there so people aren't stepping on it? Does any one else have a CB in their 3rd gen?
Old Apr 28, 2008 | 08:38 AM
Shadow-D's Avatar
Re: Installing CB Radio... Few Q's about where to run wires
If it was me, I'd run the wire under the "Rocker Panel" and cover under the carpet. Just make sure it is stretched out and not in areas that your or your passenger's feet will be all the time so you don't ware out the wire as that will cause it to short out in time.
I didn't think anyone but truckers still used CB Radios
Old Apr 28, 2008 | 08:47 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
and off-road guys
Old Apr 28, 2008 | 10:54 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i have a CB in my 83 bird. i ran the electrical connections through a small hole i drilled in the firewall. the antenna is a magnet mount and i ran the cable under the drivers lower dash panel, through the center console, out and under the seat, and then up and under the hatch weatherstripping. i'll take some pics of how i mounted the CB and the antenna. i made it so it's easily removable b/c i don't use it everyday.
Old Apr 29, 2008 | 02:22 PM
Kevman's Avatar
Engine: 2004 LQ4
That's kinda what I'd like to do, punkdude908, except mine has a cigarette lighter 12 volt connector. Now all I need is the antenna..
Old Apr 29, 2008 | 03:20 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Originally Posted by Toehead
and off-road guys
Thats a negatory...
Old Apr 29, 2008 | 08:38 PM
Kevman's Avatar
Engine: 2004 LQ4
Pigpen.. This here's rubber duck.. You got a bear report on the I42?
Old Apr 30, 2008 | 05:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
What's a CB?
JamesC
Old May 3, 2008 | 12:57 PM
Kevman's Avatar
Engine: 2004 LQ4
So it's all good. Everything is hooked up.. So I drove around last night trying to pick up a signal, and could not. We tested it out today with a handheld, and it sends the message, but does not recieve.. I'm about to take it apart, what to do now?
Old May 3, 2008 | 01:02 PM
Engine: LO3
Did you drive it to the truckstop to get it tuned yet? They might be able to help you out...
Old May 3, 2008 | 01:16 PM
Kevman's Avatar
Engine: 2004 LQ4
I ordered a SWR on eBay, we don't really have a truck stop here, it's just a gas station, really.
Old May 3, 2008 | 07:31 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Just a thought, did you have the squelch turned up? That can keep you from hearing a reception, but not affect transmission. Start with the squelch all the way down, then turn it up until the background noise goes away.
Old May 4, 2008 | 09:09 AM
Kevman's Avatar
Engine: 2004 LQ4
I had it turned up all the way I believe, probably why no one replied to my "Breaker Breaker 1 - 9er shoot me a mic check"
Old May 4, 2008 | 09:27 AM
Engine: LO3
You have got to be near a highway or something too. Or, drive up to the top of the highest hill in town and sometimes you can hear ppl miles and miles away.
Old May 4, 2008 | 10:20 AM
MIKE1988GTA's Avatar
Car: 1988 GTA
Engine: 5.7v8
Hey, u didn't say what kind of antenna you're using.Go for something good like a Wilson 500 magnet antenna.That can make a big different in what you hear and if other can hear you.
Old May 4, 2008 | 02:45 PM
Kevman's Avatar
Engine: 2004 LQ4
I have a 3 foot high whip, with a magnet base.
Haha, The nearest hill is in Kitchener... 2 1/2 hours away..
RazorN8
Jan 7, 2022 11:44 AM
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
