Help Fuse Block
Old Jul 4, 2008 | 06:06 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Help Fuse Block
Ok I have been tracking down a battery drain on my 86 Iroc. I have tracked it to the fuse thats marked " LID " I have searched all over but can't find anything that goes with lid. Does anyone have any idea what LID means. I was thinking maybe that was for the hatch motor because I do not have an underhood light.
Old Jul 7, 2008 | 01:18 AM
paycheck0171's Avatar
Car: 1985 Z28
Engine: 350 Carb
Transmission: 5 speed
Re: Help Fuse Block
The LID fuse is for the hatch pull down motor. I had the exact same thing happen on my 89 RS.
Old Jul 7, 2008 | 06:50 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Re: Help Fuse Block
my pull down motor is working fine so I don't know why it is having a power drain.
Old Jul 7, 2008 | 11:09 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Help Fuse Block
The LID fuse should be powering only the hatch pulldown motor and the trunk light. Is there a chance that the previous owner hooked up something in the trunk to this circuit?
I assume you already checked that the light shuts off when the hatch is closed.
I'd pull the fuse and measure the drain current.
Then I'd pull the connector on the pulldown motor and measure the current through the fuse again. That will tell us a little bit more.
Lou
Old Jul 21, 2009 | 11:02 AM
leech3000's Avatar
Car: '86 Trans Am
Engine: 5.0 HO
Transmission: TH700R-4
Axle/Gears: 2.77 Posi (BW)
Re: Help Fuse Block
Wait a minute....that light is suppose to go off when the hatch closes? Mine has an on/off switch and when turned on, never goes off.
Old Jul 21, 2009 | 12:20 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Help Fuse Block
does it stay on when you turn the car off?
let me know if you need a schmetic of that area? pm me and i will post it on this board.
Old Jul 21, 2009 | 12:54 PM
leech3000's Avatar
Car: '86 Trans Am
Engine: 5.0 HO
Re: Help Fuse Block
It does stay on when the car is off. Other weird things happen too.
1) The headlight switch gets warm/hot.
2) Voltmeter shows high load when anything is turned on, especially brake lights and/or headlights.
3) Hazard lights are almost non-functional.
4) Right blinker does not blink with lights on.
Old Jul 21, 2009 | 12:57 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
Re: Help Fuse Block
the early irocs 85-87ish had a switch for the trunk light and were not activated with the pull down motor. the later ones 88 and up worked when the trunk was released and when the trunk closed it went off.
as far as your problem, to make sure its coming from there i would pull the fuse and see if the drain goes away. its the simplest way to start.
Old Jul 21, 2009 | 01:13 PM
leech3000's Avatar
Car: '86 Trans Am
Engine: 5.0 HO
Re: Help Fuse Block
Well, semantically, it's not a 'drain', more of an excessive load. The battery does not drain when the car is off and I let it sit. It has sat for over a week with no problem starting again.
gta892000
Aug 11, 2019 11:16 AM
AmorgetRS
Sep 28, 2015 09:33 PM
Johnoooooo
Sep 22, 2015 08:55 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
