electronics wiz's please help voltage/electrical issue
Old Aug 12, 2008 | 07:44 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i have a 1986 tpi v8 trans am for those who may need to know.
ok i installed a digital dash and whenever i turn on any accessories like power windows or headlights or even turn signals the temp/h20 display goes way up
even when i hit my brakes to stop or slow down
even when i shift out of park and into drive the gauge is slightly affected due to the shifting gear switch
like just normally turning on the car, guages reads around 80ish because its summer time here. gauge will climb in value until it hits 215-220 as the car is on for a period time
normally driving around no headlights gauge will read about 215-220 degrees
i hit the brakes it will go up to 240ish
and brakes + headlights on = 260-280 degrees on the dash
i put down the headlights and let off the brakes and the gauge goes back to 220ish
same deal with putting my windows up or down. as soon as i stop usign the buttons the gauge goes back to normal
a friend said i needed a 12v relay for the gauge? is this so?
then another problem is i noticed my headlights dim when i use the power window switches
its really annoying with all these problems any solutions would be great.
and this may be the whole problem but im not sure please read and tell me what you think.
the preivous owner told me to keep this wire spliced or the car wont run. he said it was a wire that was spliced into an old after market security system but was since removed.
in front of the battery the owner has this semi-thick orange wire thats coming out of a harness that appears to be going to the firewall.
this orange wire is being spliced directly to the positive harness from the battery.
could this be causing my electrical issues? and how could i go about fixing it?
i dont see how my alternator could be the issue. i am able to start my car everyday and drive it everyday.
Old Aug 12, 2008 | 01:22 PM
Bobby_80s's Avatar
Axle/Gears: no idea
Re: electronics wiz's please help voltage/electrical issue
come on guys, ground problem, voltage regulator, alternator tapped into a 5v wire of a 12v wire
help me narrow down the possibilities
Old Aug 12, 2008 | 01:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How much is "way up"?
Old Aug 12, 2008 | 02:03 PM
Bobby_80s's Avatar
Axle/Gears: no idea
normal-215-230 depending how hot it is outside, day or night or how fast im going to get some nice cool air to cool the engine.
once i turn on my headlights it could jump 30degrees on the dash
brakes add another 20 degrees
and the nubers jump up n down 2-3 degrees when i use my turn signal
Old Aug 12, 2008 | 02:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What does this mean, exactly?
Old Aug 12, 2008 | 05:09 PM
Bobby_80s's Avatar
Axle/Gears: no idea
alternator, tapped into a 5v wire of a 12v wire sorry missed a coma after alternator was just trrying to list possibilities
anyways from my knowledge there aree 5 volt and 12 volt wires that can be tapped into/spliced into/connected to - to power car accesories or additional components a car didnt originally come with
Old Aug 12, 2008 | 06:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, there are no 5 volt sources that you should be tapping into. How is it actually wired?
Old Aug 12, 2008 | 06:53 PM
Bobby_80s's Avatar
Axle/Gears: no idea
i believe my digital gauge is spliced into the stock 12v and ground that originally supplied the original cluster
i did this to avoid problems but i guess not
MM2Robinson
Oct 1, 2017 09:16 AM
86CamaroDan
Sep 29, 2015 10:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
Fronzizzle
Sep 8, 2015 12:10 PM
