What bulbs?
Old Aug 29, 2008 | 05:50 PM
Kwijybow's Avatar
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
What bulbs?
So I noticed my spoiler brake light wasn't working so I removed to to replace the bulbs...and it turned out the previous owner removed them and didnt replace them so I don't know what bulbs it needs. Does anyone have a model number for the bulbs?
Old Aug 29, 2008 | 08:34 PM
CamaroRider's Avatar
Re: What bulbs?
I do not have the part number but I remember at the time I replaced one of mine (about 10 years ago) the price was $10.00 for each bulb !! To replace 5 bulbs would have cost me $50.00 I just pulled my assembly and I have only two installed. set up so that they were in bulb slots 2 and 4 (evenly spaced across the assembly). The cost is probably the reason the previous owner did not replace the bulbs. But I think according to law ALL your brake lights must be working. So I better buy three more.
Also, if I remember correctly, you must not touch them with your hands (avoid getting oil from your fingers or any other substance on them) because it will shorten the life considerably. Apparently they operate very hot.
Read this thread:
https://www.thirdgen.org/forums/conv...questions.html
Also, try the 'Search this Forum' tool and use words together like:
third brake bulb
and see if any of the returned posts looks interesting.
Old Aug 29, 2008 | 10:21 PM
Kwijybow's Avatar
Engine: Carb'd 305
Re: What bulbs?
so I checked canadian tire and they dont have them. anyoner think lordco might? I just missed them closing.
Old Aug 30, 2008 | 01:33 AM
GMLSX's Avatar
Car: 1998 Slow
Engine: Too Small
Re: What bulbs?
you dont have a radio shack up there? try this...http://www.radioshack.com/product/in...Id=2062389&cp=
Old Aug 30, 2008 | 04:24 AM
Kwijybow's Avatar
Engine: Carb'd 305
Re: What bulbs?
I do actually have a radio shack up here...well actually its called The Source by Circuit City but I bet they will do well enough. Thanks.
Old Aug 30, 2008 | 01:20 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: What bulbs?
The bulb number is 891, IIRC. They're expensive because they're halogen bulbs.
Old Aug 30, 2008 | 05:54 PM
Kwijybow's Avatar
Engine: Carb'd 305
Re: What bulbs?
Thanks for the link, I found them. Replaced and working fine.
Old Aug 30, 2008 | 06:32 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: What bulbs?
There is a guy that sells an LED conversion for it that is pretty damn cheap cost wise. I've posted the link many of times before. I don't feel like searching right now for it. I have the link saved on my home computer, if I remember, maybe I'll post the link again when I am at home.
Fronzizzle
Feb 9, 2017 09:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
podiatra
Aug 31, 2015 09:53 AM
