Tachometer not working 1991 z28
Old Aug 30, 2008 | 10:00 AM
scottjake's Avatar
Car: 1992 Camaro Z28 Convertible
Engine: 5.7TPI transplant
Transmission: a4
Axle/Gears: 3.08
When I got this car, the tachometer was not functional. Its always pegged at 6500rpm, but when you start the car it goes through its check and goes back to about 4500rpm then back to pegged. Is this an external or internal cluster problem.
I need to replace some light bulbs in the cluster and hope that i can fix the tach. any help is appreciated.
scott
Old Aug 30, 2008 | 02:23 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Re: Tachometer not working 1991 z28
Heres the fix. Take the needle off. Crank the car up. Let it warm up, if you know your minimum idle speed this will be easy. Once its warmed up, put the needle on slowly, making sure you put it on at what the minimum idle should be, and it should stick at that rpm, and be functional through all rpms.
Old Aug 30, 2008 | 06:39 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
WTF is that????? GHETTO. Don't listen to him. Here is a thread on the proper way to do it, there is no reason to take the needles off the clusters on these to recalibrate them.
https://www.thirdgen.org/forums/elec...light=fix+tach
Old Aug 30, 2008 | 09:44 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Well, that's what all the shops told me to do in order to fix mine, and you know what? It worked! Also I thought that link was just to re-calibrate, if you read his post, his tach isn't working?
1992rs/ss
Jan 31, 2025 05:10 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ChevyZ71
Aug 13, 2015 07:30 AM
