alternator ?'s
Old Oct 8, 2008 | 08:29 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
alternator ?'s
My motor is out of an '88 and the alternator is bad... Can i use an alternator from an '86 and just swap the pulleys??
Old Oct 9, 2008 | 08:42 AM
kcb37's Avatar
Re: alternator ?'s
Did you take the alt off the car when the engine was changed, or did you use the 88?
You may try looking at both at a parts store.
Old Oct 9, 2008 | 02:43 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Re: alternator ?'s
no... the alt is on the motor... an alt for an '86 is cheaper... thats why i'm asking.
Old Oct 9, 2008 | 04:28 PM
10secondhopeful's Avatar
Car: '84 Z28
Re: alternator ?'s
Damn, I don't even know the year of my alt lol. Mine went bad and a friend of mine said he had a GM truck alt if i wanted it, i was like, what the heck, and i hooked up fine, runs fine too, must be more techical on TPI motors or something...
Old Oct 9, 2008 | 08:27 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Re: alternator ?'s
its the connection for the wiring harness that i'm worried about
Old Oct 10, 2008 | 04:59 AM
kcb37's Avatar
Re: alternator ?'s
Take the one on the car to a parts store, and compare it to an 86 alt.
Old Oct 11, 2008 | 03:57 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: alternator ?'s
no an 86 WILL NOT fit they use a smaller alt in 88 86 had that big one and the plugs are different for those years the amps are diff too i think
Old Oct 13, 2008 | 07:04 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: alternator ?'s
Size of the alt doesn't matter, it's the guts. The <87 cars had an older style, rebuildable alt, whereas the 87-whenever cars have one where you have to replace the whole thing if one little piece inside goes bad, so they get to hose you for more. The newer one is controlled either by the ECM or some other means (depending on the car you have, obviously), which also means it costs more.
Old Oct 13, 2008 | 10:30 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
Re: alternator ?'s
hello, i got a question would i be able to put in an alternator off a 4th gen firebird in my GTA since the connecters are the same on the alternator only thing diffrent is the size and amperage the original is supposed to be a 105 amp the one of the 4th gen firebird is a 140 amp
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
