Gage cluster problem....advise needed ASAP
Old Nov 25, 2008 | 08:25 AM
vargasjc's Avatar
I am thinking about buying a 89 camaro RS...the problem witht the car is that the speedometer on the car its not working...I dont know how big of a problem that is and dont know how fixable it is...
Maybe gage cluster is broken or something.... is not wired right or something on the engine is messed up...Please help me out with some advise...
The fuel meter seems to be working and the temp gage seems to be working, I dont thing the milage on it is right...because It not rotating either...
The car seems to run great though when i test drove it...pretty clean engine and "reads" 80K miles (but like i said ...the thing isnt working so i am sure its more
Old Nov 25, 2008 | 08:51 AM
andresinibus's Avatar
Car: 85 Z28 W/T-Tops
Engine: 383 crate engine edel carb n headrs
Transmission: ex700R4/NOW T5
Axle/Gears: 3.08 std
Re: Gage cluster problem....advise needed ASAP
when you test drove it did it show how fast you were going m/h if it did probably the odometer inside the cluster its broken and you need to replace the cluster or fix the odometer if speed wasnt shown speed needle didnt move from 0 miles while you test drove it then the problem its the speedometer cable being broken or disconected in which case it needs to be replaced or reconected check for either or and fix accordingly as for it being only 80000 miles i really doubth it since odometer its not rolling since who knows when
Old Nov 25, 2008 | 08:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A couple of links that might prove useful:
https://www.thirdgen.org/forums/inte...eedo-woes.html
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Nov 25, 2008 | 09:02 AM
vargasjc's Avatar
when I test drove it...the odometer didnt rotate at all...so I know its not working...the speedometer stayed at 0 the whole time...
the fuel level was right at the middle (hard to tell if its working or not...same for the temp level
The one thing that was working for sure was (the one that goes from 0-8 or 0-6) dont know the name for it
Old Nov 25, 2008 | 10:09 AM
vargasjc's Avatar
Anyone???
Old Nov 25, 2008 | 10:17 AM
JamesC's Avatar
One link above describes reasons for mechanical speedo malfunction, the other how to repair the trip. Did you read those?
JamesC
Old Nov 25, 2008 | 10:45 AM
como te dije juan carlos es probablemente tu velocimetro desconectado o roto revisalo o sigue las links que te dejo james para un procedimiento mas detallado
Old Nov 25, 2008 | 01:51 PM
vargasjc's Avatar
JamesC
So what you are saying is that there is something wrong with the gage cluster for sure? and that the only thing wrong...i mean...is it possible that something on the engine is messed up or tranny
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Irocohio
Aug 12, 2015 08:03 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
