fuse blowing out! dome light, locks horn and gauges
Car: 1990 RS tbi camaro
Engine: 5.0 tbi stock, hooker headers
any 1 know what could be shorting out my fuses? My door locks, horn, trunk latch, dome light,and gauges work for a while when i replace the fuse but then it shorts out in time. and as soon as i put in a new fuse in lil sparks come from where i just put the new fuse but it works for a awhile, it doesnt immediately short out right when i put the fuse in... any ideas?
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: fuse blowing out! dome light, locks horn and gauges
I had the same problem. Turns out I had a penny stuck in my cigarette lighter... I now no longer keep change in the ash tray!
Transmission: T-5, TH350, T-5
I had the same thing! Check your cig lighter
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
similar issue, my cig lighter just had corrosion and it was causing the electricity to arc to ground and blow the fuse, you can pull the assembly out and clean it off with some emery cloth, does wonders lol
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
+3 on the cigarette lighter...
ill check my cig lighter thnx guys..... hope thats whats wrong with mine since i dont have a cig ligther in the socket its just empty hope that works
Car: '88 Firebird Formula
Engine: 355 TBI
Axle/Gears: 10 bolt
What fuse is getting blown out? My firebird's had this problem for a while, I thought is was something highly complicated... what a relief.
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
It's the accessory fuse. 20amp yellow more or less in the middle of the fuse block
Car: 1987 Trans Am
well, mine started blowing out again and the cigarette lighter has been disco so I should have fun this weekend chasing the short down...*grumble*
Car: '91 Z-28 2007 F-250
Engine: 5.7
Axle/Gears: 4.10
Cig lighter as well. I don't push it all the way in. I leave it half way out....just enough to keep it there but not to make contact.
Ghettobird52
Jul 5, 2024 11:18 PM
