Need help with a 92 speedometer
Old Dec 28, 2008 | 01:36 AM
Keith5875's Avatar
Car: 1989 GTA
Engine: 5.7
I have a 92 RS 305 and the speedometer stopped working. I started the car and smoke came out of the dash. After I opened the instrument cluster I found a burned resistor in the circuit board below the speedometer. After doing some research I found that it is a 3.9 ohm resistor, so I replaced it hoping that it was a one time occurrence but it just fried that resistor as well. I know that there is a short some where but I cant find any schematics to trace it out. If anyone has had this problem before, any advice would be appreciated.
Old Dec 28, 2008 | 03:39 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: Need help with a 92 speedometer
Solder on a new resistor then try unplugging the spedo sending unit in the drivers side of the transmission. Just a thought
Old Jun 2, 2009 | 09:24 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Anyone else have the same issue. My cluster did the same thing, but I have no ECM and I swapped to a th350 so the speed sensor is not hooked up?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
