Brake lights lit up
Old Jan 10, 2009 | 08:21 AM
SLOWMARO355's Avatar
Brake lights lit up
New pads, shoes, hadware kit, wheel cylinders. Brake have been bled.
Could this be the master cylinder?
The parking brake light blinks on when braking, off when driving. Sometimes stays lit.
Old Jan 10, 2009 | 08:27 AM
Stephen's Avatar
Car: 87 GTA
Re: Brake lights lit up
No clue what your problem even is......Try rewording it & we'll see.
Old Jan 10, 2009 | 09:53 AM
The light wont go off.
Old Jan 10, 2009 | 09:59 AM
Stephen's Avatar
Car: 87 GTA
That's not much help, in the way of EXPLAINING of what you mean..
But......None of those parts you have listed above, have anything to do with the LIGHTS. Check the switch on the brake pedal lever.
Old Jan 10, 2009 | 10:16 AM
Well it just came on recently. My wheel cylinder was in piecis inside the drum, and my adjuster was rolling around too. I heard it rattling when backing out. The light came on after that. I replaced everything, bled system, and lights still on.
Old Jan 10, 2009 | 10:19 AM
Stephen's Avatar
Car: 87 GTA
But again...Those parts have NOTHING to do with the lights. The lights are controlled by the box on the top of the pedal shaft, under the dash.
I think you've been chasing the problem, by attacking the wrong area.
Old Jan 10, 2009 | 10:25 AM
What would cause it to blink on and off? The brakes feel different also. This needs to be fixed b4 I drop my motor/trans in. I wanna be able to stop!
Old Jan 10, 2009 | 11:32 AM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
i think he means the brake light on the dash
Old Jan 10, 2009 | 11:59 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
could actually have nothing to do with the brakes. Just like Stephen is telling you the only controller to the brake light switch as far as I remember is the switch on the brake pedal (well above it) and the blinking on and off could just mean the wiring is to blame, possibly bad ground or broken wire. any of the 3rd gen cars aren't as advanced as the ABS equipped cars meaning there isn't a clusterf*ck of sensors for the seatbelts brakes etc.
Old Jan 11, 2009 | 01:21 AM
Car: 86 Z28
my 86 has a seatbelt light and brake light on the dash, but the seatbelt sensor has been bypassed
Old Jan 11, 2009 | 05:35 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Hes talking about the brake light..... I had the same issue, got it to go away for months but it recently came back. I beleive air in the lines causes this or a problem with the vacuum. I would suggest bleeding all of the brakes again really really well.
Old Jan 11, 2009 | 09:46 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Stephen is right, good wording is fundamental to finding the cure for the problem.
If one isn't willing to word their problem right, then who would be willing to read it and help find the cure?? (and it sure helps knowing English and spelling when posting a problem)
But I'll be a nice guy (since it's such a great sunny cold day outside ).
IF the problem is with the brake WARNING light in the dash, then I'd look at the connector on the master cylinder. If the connector is tight and clean, then it could be that either the front or the rear brake lines aren't bled 100%. The switch on the master cylinder is called Brake Pressure Differntial Warning Switch and if there is difference in the lines pressure, it will light up.
I just read in one post that "The brakes feel different also." Insert a big "duh" here. The brakes need to be bled, period.
Hope this helps.
Lou
Old Jan 12, 2009 | 08:30 PM
Hope this helps.
Lou
I bled them again in order this time. Brakes work damn good now. Light never went off though so I unplugged the switch.
Old Jan 13, 2009 | 11:43 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Think it could be a faulty Sensor on the master cylinder?
Old Jan 14, 2009 | 08:19 PM
Possibly. Once I put my transmission back together. Im throwing all that computer controlled crap in the trash.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
