brake lights not working
Old Jan 23, 2009 | 06:07 PM
a1990camaro's Avatar
Car: 1990 RS tbi camaro
Engine: 5.0 tbi stock, hooker headers
my 1990 camaro brake lights work some times other times they dont. what fuses are connected with the brake lights? and i know its not the bulbs. i dont have i a radio in my car but all the wires are taped up. the tail lights itself works but not when you press the brake
Old Jan 23, 2009 | 07:53 PM
91camaro454's Avatar
Car: 91 camaro rs
Re: brake lights not working
sounds like your brake light switch on the upper part of the brake pedal . usually about 10 dollars and 15 minutes to fix .
Old Jan 23, 2009 | 10:54 PM
sharonq's Avatar
I too have replaced the brake light switch but still can't get the brake lights to work. Hazards do not work eigther. Also the park brake when engaged doesnt make the lights come on dash or tail lights. (in fact it doesnt seem the park brake works mechaincally) YES we checked the fuse and have power at the fuse block. We are new 87 Firebird owners and really anxious to get our project tagged and rolling.
What should we try next? Is the park brake switch in the loop with the brake lights??
Old Jan 24, 2009 | 10:15 AM
Car: 91 camaro rs
okay you have several things here and I will try to help. first your hazards. when you pull the button out do the lights come on or not outside the car ? If they do come on just dont blink , its your emergency flasher .If they do not come on it it probaly the turn signal assembly in the column. Both are not hard fixes with a haynes or chiltons manuel. Your brake lights it says you have replaced the stop light switch , however did you check for consistant power at the switch before you replaced it ? have you checked for power on the circuit on the pigtails in the rear when the brake is pressed ?If you have power on the switch wire its between the switch and the tail lights , if not the problem is the power to the switch . now your emergency brake (which sounds like your rear shoes need replaced and adjusted) has nothing to do with the rear tail lights they do not come on when the e-brake is pulled only the light on the dash does (which probably is burnt out or the switch on the e-brake needs adjusting or replacement)
Old Jan 25, 2009 | 04:22 PM
sharonq's Avatar
It is the fuse block; fuse is good, but no power at the block. That explains why the hazards dont work either. Thanks for the help!
Old Jan 25, 2009 | 05:30 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
I have found that if fuse taps are used they can spread out the contacts in the fuse panel causing things to not work. Just another thought.
Old Jan 26, 2009 | 11:07 PM
what the hell man this is my post for a 1990 CAMARO NOT FIREBIRD POST YOUR OWN ****. can someone please help me and not ask questions for them selfs for a car that isnt a camaro. my brake lights work sometimes. can someone tell me what fuses are responsible for the brake lights to work,and what other causes there might be
Old May 24, 2009 | 02:52 PM
MADMAXGTA's Avatar
Car: 89 TTA
LOL BANNED! anyways...my brake lights stop functioning to..my third brake light comes on but no tail brake lights,fuse seems fine,bulbs seem fine,all other lights work ..idk any ideas? thx!
Old Aug 31, 2021 | 07:54 PM
flychicken's Avatar
dude really come on now genius firebird in the Camaro are the samecar
Old Aug 31, 2021 | 09:57 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Lol. This thread is 12 years old.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
