Speedometer
Old Feb 6, 2009 | 12:07 AM
88 Camaro Kid's Avatar
Car: 87 Camaro Sport Coupe
Engine: 305 TBI
Transmission: Automatic
Speedometer
Ok i got a 87 sport coupe 305 and i cant get the speedometer out plz help
Old Feb 6, 2009 | 12:53 AM
STRIKER911's Avatar
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Re: Speedometer
More info please. Its been two years but I might b able 2 help. If I remember right I had to take the cable out from under the dash. Its in a tight spot, & yes it may not be possible to pull it out first to get it unhooked.
Old Feb 6, 2009 | 01:02 AM
Engine: 305 TBI
Re: Speedometer
i cant find the eletronic disconnect thats what the book says to find but idk where that is at
Old Feb 6, 2009 | 02:40 AM
STRIKER911's Avatar
Car: 89 RS
Re: Speedometer
The electronic gauge was on 1990, & up cars. Its the cable. It can not be pulled unless it is disconnected first. It also has a retaining clip. You will get it. I remember yelling, cursing, & throwing. I used a longer then normal flat head to press on the retainer. It was not an easy deal. You can pull on the cable while using the screw driver with your other hand. Get a light that fits on your head if you can, or fight with a flash light rested on your shoulder like I did. I bought a head light later for things like that. Works great. Get the one that can be adjusted for aiming the light where you need it. May also help to take the driver seat out. My whole interior was out of the car, other then the dash at that time.
Old Feb 6, 2009 | 02:51 AM
Engine: 305 TBI
Re: Speedometer
Yeah i just found that cable ur talking about just press that piece that presses in right?
Old Feb 6, 2009 | 02:55 AM
STRIKER911's Avatar
Car: 89 RS
Re: Speedometer
yep its a retainer. press & pull deal.
Old Feb 6, 2009 | 02:57 AM
Engine: 305 TBI
Re: Speedometer
ok now how do i get it back in?...yup an hour ago i was cusing and throwing things to lol
Old Feb 6, 2009 | 03:04 AM
STRIKER911's Avatar
Car: 89 RS
Re: Speedometer
Should just have to line up the cable with the speedo, & push it in. Try not to jam it in. They are very sensitive. If you push to hard you will get speedo noise after its all said & done. I had to pull the cable down a few times to turn it in order to get it just right. you can also do one of two things to keep the speedo from moving while you push on the cable. bolt it all back up, or push the opposite side by hand. Like pluging in a drop light to an extetion cord.
Old Feb 6, 2009 | 03:06 AM
Engine: 305 TBI
Re: Speedometer
oh since we are on the subject of gauges b4 i pulled the gauges wen i would give it gas there was a clicking noise in the gague area any ideas?
Old Feb 6, 2009 | 03:10 AM
STRIKER911's Avatar
Car: 89 RS
Re: Speedometer
no help on that one. take it all the way out and investigate/lube or whatever you think might help. Never messed with the internals.
Old Feb 6, 2009 | 03:15 AM
Engine: 305 TBI
Re: Speedometer
naw i think its that clicking u were talking about with the speedometer
Old Feb 6, 2009 | 03:26 AM
STRIKER911's Avatar
Car: 89 RS
Re: Speedometer
yes it is. just dont know how to fix it. bet if you post about it people will help that have had the same problem
Old Feb 6, 2009 | 03:28 AM
Engine: 305 TBI
Re: Speedometer
Ok will do
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
