85 2.8 alterntor upgrade ?????'s
Old Feb 24, 2009 | 03:13 PM
elthomas's Avatar
Car: 1985 Camaro
Engine: 2.8l v6
Transmission: auto
Has anyone upgraded the alternetor in an 85 2.8l camaro, can i use the cs144 alt. on this car and what all would I need to change or add.
Old Feb 25, 2009 | 05:05 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: 85 2.8 alterntor upgrade ?????'s
85 should use the SI type alternator I think but either way get a CS130 and either convert or upgrade the one you have. I used my old one from my 92 V8 camaro and changed out the case so it would work with the 2.8 brackets, so I went from a 70amp to a 105amp alternator for free.
Old Feb 25, 2009 | 11:37 AM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
the CS-144 alternator WILL work with minormods, its a 20 minute job at most
Old Feb 25, 2009 | 11:43 AM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
it would be easier to take it to a alternator shop..let them beef it up and keep your same caseing..thats what i did..went from 80 to 160 amp and spent about 50 bucks to do it..took them about 1.5 hrs
Old Feb 25, 2009 | 05:28 PM
elthomas's Avatar
Car: 1985 Camaro
Engine: 2.8l v6
Transmission: auto
I wasn't sure because i haven't been able to find anyone on here that has a 2.8 v6 that has done it, i did a search and didn't come up with anything, what kind of mods need to be done?
Old Feb 27, 2009 | 06:55 PM
Chevy8588's Avatar
all you need to do is remove the old pulley from it, put the pully from your current alternator on it, and then take the 4 houseing bolts out and WITHOUT separating the housing, turn it so your plug is exposed when it is in the car, make sure u have the correct plug for the 144, and wire it up the same as the original one is,
Linson
Oct 24, 2025 02:00 PM
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
Zell1luk
Sep 29, 2015 10:36 AM
spartanreaper
Sep 25, 2015 07:22 PM
