brake lights
Old Mar 4, 2009 | 03:10 PM
AKATDOG's Avatar
Car: 84 Z28
brake lights
ok first i was having a problem where the fuse would blow every time i pulled the light ****, it ended up being a bad ground for the radio, now i got that solved i have no brakes lights, all the other lights work fine, where should i start ?
Old Mar 5, 2009 | 04:11 PM
AKATDOG's Avatar
Car: 84 Z28
Re: brake lights
anyone ? i read something about the brake light switch, could this be the cause ?
Old Mar 5, 2009 | 06:27 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: brake lights
There is a plunger switch against your brake peddle. There should always be power going into it and the other wire hot when you push the peddle in. You'll want a test light probe. Got mine at the dollar store.
Check all your fuses.
Old Mar 15, 2009 | 11:43 AM
AKATDOG's Avatar
Car: 84 Z28
Re: brake lights
ok so i finally got a chance to check this today (nice weather) the switch has 2 plugs in it (one white one black) with two wires in each, in the white plug with the brake pedal depressed both wire have power and when pressed only one has power, the other plug (black) has no power weather its depressed or not, is it working right ? what esle should i check, Thanks.
Old Mar 15, 2009 | 05:32 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: brake lights
The brake pedal switch you're looking for has an orange wire and a light blue wire. The orange wire supplies 12V from the fuse and the switch sends it to the brake lights through the light blue wire when the pedal is depressed.
With a test light, it should be pretty easy to find out whether the switch is operational or not.
Wiring diagram here: http://www.geocities.com/vtcamaro/Pi...rams/pg186.jpg
Hope this helps.
Lou
Old Mar 15, 2009 | 06:04 PM
AKATDOG's Avatar
Car: 84 Z28
Re: brake lights
is it not the switch at the top of the brake pedal similar to this
Old Mar 26, 2009 | 12:52 PM
AKATDOG's Avatar
Car: 84 Z28
Re: brake lights
OK, still working on this any help much appreciated, can someone tell me if my switch is working correctly, everyone says the switch only has 2 wires but mine has 4 and i labeled the picture for details, Thanks.
Old Mar 26, 2009 | 04:05 PM
BigBadLou's Avatar
Engine: TPI
Re: brake lights
Yup, the orange and blue wires are for the brake switch.
If you don't have any power to the orange wire, check the STOP/HAZ fuse. Even if it's good, it might be not seated 100% right, causing bad contact.
Do your hazards work?
Lou
Old Mar 28, 2009 | 02:41 PM
AKATDOG's Avatar
Car: 84 Z28
Re: brake lights
Lou
Thanks for the help lou, for some reason when i pulled the hazards the fuse would blow, i put a 10amp fuse there (was a 5 amp) and it seems to be working now, brakes and hazards... not sure why there connected, dont they have seperate fuses ? also is it ok that i used a 10amp fuse instead of 5 ?
Old Mar 28, 2009 | 10:56 PM
BigBadLou's Avatar
Engine: TPI
Re: brake lights
No wonder the fuse blew, somebody put a tiny fuse in there. That circuit feeds the stop lamps (60W) and hazards (80W) so the fuse rating is 20A. Put in the right fuse size and you should have no problems now.
Lou
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
